I had had a decent exhaust leak at cylinder 1 and 3 but was afraid to pull the manifold because of the bolt shear I kept reading about, I heard about a 50/50 blend AFT and acetone, tried it and it didn't burn off like PB does when ran fairly hard so after another hot manifold application and overnight soak a few decent smacks with a rubber mallet on my box end 13mm and they all broke loose no problems. arty018: The same goes for turbo studs.
All in all it worked great, didn't see anything pertaining to home made penetrant in my search of the forum and just wanted to share the info :thumbsup:
Although the vinagerette residue in the bottom of the bottle I dug out from the recycle may have helped, that stuff had some umph to it.
