Part numbers for a piston pump conversion - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 01-09-2006, 01:18 AM Thread Starter
Paccool's Avatar
The following are the parts needed to make the conversion from the diaphram lift pump to a piston lift pump.
Part numbers are Cummins numbers
Pump - 3036320
1 fuel tube from pump to fuel filter -3914753
2 gaskets - 3939258
2 sealing washers for banjo bolt at filter - 3963983
1 spacer to move pump out 1/4" - 3914284
2 new pump mounting screws - 3900631
I got all my stuff from Ponci Diesel - Thanks Ponci!
Stan
93 D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust, modified tranny, EGT/boost/tranny/tach gauges, TPS removed, a little chrome under the hood. Mag-Hitec tranny and diff. covers. Rear sway bar. Line-x bed liner, after market seats. Single stage Water/Meth system installed. Oversized intercooler w/3" IC lines.
05 Chevy 2500 HDcrew cab 4x4, Duramax W/Allison, 17" Hummer wheels w/285-70-17 BFG's, Banks intake, ported turbo mouthpiece. Predator programmer, Autometer EGT and boost gauges.
Paccool is offline
post #2 of 4 (permalink) Old 05-18-2006, 08:14 PM
goodtyms's Avatar
Pump - 3036320
2 gaskets - 3939258
I tried Cummins Northwest here in Seattle and they said the "1 spacer to move pump out 1/4" - 3914284" part number - it's gone obsolete.
I got the pump, line etc., but may have to make my own spacer iunless someone has a better suggestion.
goodtyms is offline
post #3 of 4 (permalink) Old 06-29-2006, 01:52 AM
Pump - 3036320
2 gaskets - 3939258
Do you have a # for Ponci Diesel? Thanx.
93 W250, 5.9L cummins, Auto, 4WD. K&N Air Filter and a strait pipe. Injector Pump tweaked. Timing bumped up 1/8". Home made propane injection and a little bit of grindage on the fuel delivery pin!
BigNorm is offline
post #4 of 4 (permalink) Old 06-29-2006, 11:27 AM Thread Starter
Paccool's Avatar
Norm, they have an 800 number but I don't have it with me. Regular number is 707-725-3307, ask for Brad.
Stan
Paccool is offline
