HX40 turbo - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 01-20-2009, 08:31 PM Thread Starter
Power Ram Man's Avatar
HX40 turbo
i have a hx35 turbo on my truck now i have a chance to get a hx40 in good condition for 100 bucks with banks big head wastgate i know its worth 100 bucks but my question is will i see any performace gains besides quicker spool up and will my head hold im now seeing 35 psi should i set the hx40 at 40 psi or higher or lower boost for the head gasket
[B]1992 W250 4x4 cummins converted to getrag 5 speed p pumped
1999 24 valve qclb built auto s300 turbo edge juice 4 inch exhaust 3 piece manifold 100hp injectors
Power Ram Man is offline
post #2 of 22 (permalink) Old 01-20-2009, 08:46 PM
crossy's son's Avatar
Well. 100 bucks is a steal for a HX-40.
The hx40 will have a TRUE 4 inch exhaust outlet compared to your hx35's 3 inch outlet so a new 4" downpipe will have to be aquired (they sell them)
The hx35 has a 56mm compressor
the hx40 should have a 60mm compressor= more air/lower egt
Depending on what exhaust housing you have on your hx35 now, the hx40 will probably spool slower becuase the compressor is so much bigger.
Things to look for-
Count the blades on the compressor wheel. Just so you know what you have
did it come off a 5.9 cummins? it has to have the right flange to mount to exh. manifold
What size exhaust housing is on it? its stamped on the back, if it has a 18cm it will be slow spooling and it will not light too quick, A 16cm was also offered on the hx40 but was kinda rare and is what you want for quick spooling and more fun.
Set the wastegate at 40 psi, anything over that your dangering your headgasket and the turbo itself might grenade in the high 40's and 50's PSI wise.
Hope this helped. BUY IT is all i can say. to answer your first question, yes you will see performance gains, and this turbo is good up to the 400 HP range and is capable of much more. The HX40 also has a sweeeeet sound as well. You have to figure in buying or just making a 4 inch downpipe to the $100 your getting the turbo for.
,Brandon
01 QCSB 2500 4x4 HO 6 Speed 16.0 1/4 ET
91.5 W250 5spd, 301hp/720tq, 15.47 1/4 ET
- Currently being restored
crossy's son is offline
post #3 of 22 (permalink) Old 01-21-2009, 12:05 AM
1ST GEN MODERATOR
Philip's Avatar
iTrader Score: 12 reviews
If that HX40 has the T3 flange 16cm housing on it. It will spool just like your HX35 will. I saw no difference in spoolup going from a HX35/16 to my current HX40/16. You will see a couple of PSI drop stepping up in size. The EGt's will be lower. Your pushing more air.
If you see a boost increase it means you were bottled up by that 3" exhaust outlet out of the turbo.
The map range on a HX40 is 45 PSI. I would set the wastegate for 40 and leave it.
2014/93 W350 DRW, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, G56 SBC Con-OFE, 3:07's axles, 2" skyjacker lift, air ride rear suspension,B&W flatbed
Philip is offline
post #4 of 22 (permalink) Old 01-21-2009, 12:09 AM
johnnyusmc's Avatar
unfortunetly i can not help you with your question but i am kind of in the market for an hx35 if you decide to sell i am interested in it
01' 4x4 long bed,75hp injectors, Edge JA w/hot unlock, 6 inch mitre cut stacks, fass 95, gorend triple disc tc, afe intake,straight pipe, scanguage II, I need a bigger turbo!! And a manual transmission
johnnyusmc is offline
post #5 of 22 (permalink) Old 01-21-2009, 10:13 PM Thread Starter
thanks for the replys the turbo is coming of a 2000 dodge cummins with 100hp injectors fass fuel system and 5inch exhaust and he says its got the 16cm with the banks big head wastegate and he also said it would bolt up to my 3 inch down pipe someting about a reducer? in the turbo housing but even if it doesent fit with the 3 inch downpipe i can resell or buy the 4inch downpipe
The Following User Says Thank You to Power Ram Man For This Useful Post:
Bdl5589 (06-25-2013)
post #6 of 22 (permalink) Old 01-21-2009, 10:19 PM
gear jammer 91"'s Avatar
If it has an exhaust housing on it with a 3" outlet it might actually be a 35/40 hybrid. Or it just has some weird reducer like the guy says. If it has the 4" outlet you would be better off to get a 4" down pipe to go with it instead of using the adapter it's supposed to have.
2016 RAM 2500 Crew Cab 4x4 6.4 Hemi
95 x-cab lb 4x4 5spd Sold, 01 LB7 Sold, 96 x-cab lb 5spd Sold, 91 W250, 436HP 968FT-LBs Sold.
gear jammer 91" is offline
post #7 of 22 (permalink) Old 01-22-2009, 07:41 AM
Just upgrade to a 4 inch downpipe, buy a first gen 4" downpipe from Stan's Headers, standard and custom high performance header designs for automotive and marine engines. no use runninga biig turbo and then hooking it back up to the factory restricted downpipe.
post #8 of 22 (permalink) Old 01-22-2009, 08:07 AM
kooimanj's Avatar
You will be fine with the 40. Like the others have said, just set the gate @40psi.
2001 Dodge Cummins Sport. Got a few goodies. Starting to gather parts for a P-Pump convert.
kooimanj is offline
post #9 of 22 (permalink) Old 01-22-2009, 07:13 PM
how do you set the gate on an hx35/hx40? i thought they were factory set or unadjustable, allen head or changing a spring like on an aftermarket unit? very interested to hear the answer
89 D350 DRW w/ Getrag 5 speed- 170K, Full Autometers, K&N, Air Box MIA, Custom 4" Turbo back W/ Race Bullet Muffler
1_BEAT_90 is offline
post #10 of 22 (permalink) Old 01-22-2009, 09:08 PM Thread Starter
well i have that system that has the 3 inch dowmpipe to the 4 i dont know if i would buy the 4inch downpipe if it would work because of the 3 to 4inch reducer after the downpipe
post #11 of 22 (permalink) Old 01-22-2009, 10:00 PM
Cut off the reducer and band clamp the DP right to the exhaust.
I really don't think you should hook the 3" DP up to the hx40,, its kinda a waste of the 4 inch oulet that the hx40 has, you won't see as much of an egt drop on the bottom end and it wont spool up as quick as a 4 inch dp would.
post #12 of 22 (permalink) Old 01-22-2009, 11:14 PM
Thumbs down Hx 40
I would be worried about a HX 40 for a 100.00
1994 12 valve 4X4 2500 Loaded Carli Suspension featureing 3" Kings Full billet Suncoast trans converter & flex plate HX 40 370 injectors -Snow Performance Meth h20 injection- gov springs- ATS manifold- AFE sock 315-75-16 Pro-Comp Extremes Wilco
Grumpy John 4X4 is offline
