Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 01-17-2009, 09:23 PM   #1 (permalink)
89cummins's Avatar
gear swap
hey guys just wondering if anyone with a 3 spd 727 has swaped the 3.07's gears for 3.54's and if so how do you like them, and is it possible to stay at highway speeds? Thanks
-89 w250 4x4, auto, 250,000 miles, ASA intake, 2 turns of fuel screw, 3 turns smoke screw, fuel pin deepest setting, 3200 spring, 5" tip, rattle can paint, glowshift boost and pyro, timing bump, 60mm gds upgrade
89cummins is offline   Reply With Quote
Old 01-18-2009, 12:51 PM   #2 (permalink)
89cummins's Avatar
bump......
Old 01-18-2009, 12:55 PM   #3 (permalink)
1ST GEN MODERATOR
Philip's Avatar
The 3:07 axles are a problem on gear changes. The housings were made differently to accept that gear ratio. The 3:54 ratios do not work in those housings.
There are people that do want the 3:07's. It wouldn't be hard to find someone to trade axles with to get the 3:54 gearing your thinking of.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, auto(G56 soon), 3:07's axles, 2" skyjacker lift, B&W flatbed
Old 01-18-2009, 01:54 PM   #4 (permalink)
89cummins's Avatar
So if I wanted to switch gears I'd need "new" axles. But do you know how 3.54's would fair with a 3 spd? Thanks
Old 01-18-2009, 02:04 PM   #5 (permalink)
1ST GEN MODERATOR
Philip's Avatar
It would drop you to about a 55 MPH truck. Right now if your throttle linkage is set properly you should top out against the stock governors around 80 to 85 MPH.
Old 01-18-2009, 08:20 PM   #6 (permalink)
89cummins's Avatar
ok wasn't sure because i've read a lot of posts about different gears in a 3 spd and every post says something different.
