91 Cummins Auto Questions - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 01-15-2009, 10:25 AM Thread Starter
DodgeRam2500CTD's Avatar
I just bought a 91 Cummins and it needs some work and I have some questions about that........Well I have a guy telling me its just a 3 spd Auto Tranny but I've looked and it seems to be a 4 spd according to the internet.......now for the problem.....it wont shift past 3rd.....it tops out at about 45mph with the 4.10 rear end......there is a linkage on the throttle that kinda has a sleeve so it can slide back and forth and is also hooked to the tranny....when the throttle is moved the linkage dont move....the throttle just slides in that sleeve.....im thinking that is what is making it not want to shift but I looked and didnt really seem to find a place to tighten it up.......heck idk maybe its supposed to be like that but thats why I am here .......The overdrive switch doesnt seem to work but that might be in with this linkage deal......
And last......this thing takes nearly 3 days and 4 nights to warm up ......It just seems like it wont warm up for anything......I can let it run for 45 mins and take off with about 4,000lbs behind it and it gradually warms up and once the temp gauge moves its all good....but just normal driving or getting on it a little bit wont hardly budge the gauge.....I'm thinking the thermostat might be stuck open but yet again idk......
Sorry its long.....I've been around diesels and know a little about them but this is my first to own and want it to really last and be taken care of so I want to learn as much as I can.....And be able to do it myself....I may need some in depth instructions but I'll get the hang of it soon I'd say
2001 Dodge Ram 2500 QC Cummins H.O. 4X4 6 Speed Airdog 150 150hp Injectors Quadzilla Adrenaline w/ Pulse Pod 5in Turbo Back Exhaust, HE351 Turbo BHAF
DodgeRam2500CTD is offline
post #2 of 14 (permalink) Old 01-15-2009, 12:37 PM
1ST GEN MODERATOR
Philip's Avatar
iTrader Score: 12 reviews
In 91 there were two different models of CTD trucks. The nonintercooled trucks had a 727 trans. This is a 3sp trans. NO OD
If the truck has an intercooler it is called a 91.5. The 91.5's had the 518/46RH transmission in them. This is a 3spd with OD trans
So the big question is. Does the truck have an intercooler.
The not warming up most likely is the thermostat. Buy one from a cummins dealer. Stay away from aftermarket parts stores.
2014/93 W350 DRW, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, G56 SBC Con-OFE, 3:07's axles, 2" skyjacker lift, air ride rear suspension,B&W flatbed
Philip is offline
post #3 of 14 (permalink) Old 01-15-2009, 01:35 PM Thread Starter
Yea it does have the intercooler
post #4 of 14 (permalink) Old 01-15-2009, 02:27 PM
1ST GEN MODERATOR
Philip's Avatar
Ok you have a 91.5 model.
That trans cable needs to be working. Its called the TV (throttle valve) cable. It controls the line pressures and up shift points on the trans. OD is controlled by the PCM (powertrain control module). The upshift to OD is somewhat controlled by that little 3 wire sensor on top of the injection pump.
There is also a temp sensor in the cooler line by the front of the trans pan. If the PCM does not see a signal from it that will stop the trans from shifting to OD.
Philip is offline
post #5 of 14 (permalink) Old 01-15-2009, 04:22 PM Thread Starter
Ok, for that linkage.......Is there a spring that is supposed to be somewhere because i can move it to wherever i want and it will stay.....
post #6 of 14 (permalink) Old 01-15-2009, 05:02 PM
Did this to mine and it's been flawless ever since. Don't go buy a new TPS! They are about $300 last time I checked the Dodge stealership.
Replacing the TPS with a potentiometer -A
troy
btw, i ended up withabout $10 and 45 min. in mine!
'92 W250 Ex-Cab, 6bt, A518, 205, 60F/70R, Dually Conversion rollin on 19.5's!
trollporter is offline
post #7 of 14 (permalink) Old 01-15-2009, 09:08 PM Thread Starter
ok this might be a real noob thing to say.....but link just confused the hell out of me lol
post #8 of 14 (permalink) Old 01-16-2009, 01:22 AM
1ST GEN MODERATOR
Philip's Avatar
There is supposed to be a spring on that TV cable. Here is apic of my linkage. Notice the spring that hooks into the throttle arm and goes towards the rear of the engine. That spring is hooked into the TV cable slide arm.
With the TV cable all the way forward the slide should have about 1/16" of clearence between it and the pin that moves it.
Troll cut that price in half.
That link is a how to on removing the TPS (throttle position sensor) and doing some jury rigging (insert the name you prefer best in the underlined area) to replace it.
Philip is offline
post #9 of 14 (permalink) Old 01-20-2009, 05:11 PM Thread Starter
I cant get that pic to work.....
post #10 of 14 (permalink) Old 01-20-2009, 05:16 PM
stabler's Avatar
troy
I also have a potentiometer setup and i love it.. I can control when OD shifts... nice for pulling heavy loads..
'92 d-250, 2wd, auto, single cab, tweaked VE pump, single 5" stack
stabler is offline
post #11 of 14 (permalink) Old 01-20-2009, 06:18 PM Thread Starter
Ok, I see that spring your talking about.....I'll hook that up........now is there a better explanation to that pentometer anywhere.....idk I just get lost when I look at it
post #12 of 14 (permalink) Old 02-02-2009, 06:25 PM Thread Starter
Another Question, lol, I just got the motor back in from resealing it. i go to turn the key to get it to crank, all i get is a click from the relay. Everything is back the way it came apart, so i cant figure this one out either. any possibilities?
