What type of oil in Getrag - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 12-19-2008, 08:41 PM Thread Starter
I have a 1993 W250 cummins
with a Getrag 360 and I want to change the oil in it. So what do I use.
The truck Manuel says 5w-30 motor oil but the Dodge dealer says some special mopar oil that is syn.
Thanks
hyde is offline
post #2 of 13 (permalink) Old 12-19-2008, 09:10 PM
5.9fan's Avatar
i would think normal 5w-30 would be fine.
there should be more info on this site, but remember to overfill by one quart. Like i said, search the site, its here, and more experienced members will chime in soon.
2014 CCLB 4x4 Tradesman. 5th wheel prep, upfitter switches, LSD, plow prep, on board air, amp bedstep
Its quiet... too quiet...
5.9fan is offline
post #3 of 13 (permalink) Old 12-19-2008, 09:39 PM
dknaks's Avatar
I run standard 5w-30 in mine, Has 255,000 on it. I overfil about a quart and a half over "stock full level". I change the tranny oil out every other engine oil change of my truck. Seems to be good so far (minus my input bearings going on the transmission.....
-07 6.7 3500 dually, Blackmaxx, SB DD3600. Fully deleted.
dknaks is offline
post #4 of 13 (permalink) Old 12-19-2008, 09:54 PM
Duluth Diesel's Avatar
The best oil for the 5 speed Getrag on first gen trucks would be AMSOIL Signature Series 0W30 Synthetic.
-Chuck
Duluth Diesel is offline
post #5 of 13 (permalink) Old 12-20-2008, 12:06 AM
Royal purple syncro max. And over fill that thing.
1990 w350 dually getrag
1994 2500 srw for chevy conversion
12valvechevy is offline
post #6 of 13 (permalink) Old 12-20-2008, 02:26 AM
nooblet's Avatar
i run the same 15-40 in my engine, tranny, and t-case.
Chris
'90 W250 Non-IC'd / Lockers / POD's / 366 Spring / BHAF / Getrag / Valair Ceramic /3.54:1s / 35" BFG MTs / Phantom II Boost/Pyro
nooblet is offline
post #7 of 13 (permalink) Old 12-20-2008, 04:28 PM
wjones's Avatar
im suprised the amsoil dealer wouldnt recommend AMSOIL Synthetic Synchromesh Transmission Fluid (5W-30).
, nv4500, Club Cab
wjones is offline
The Following User Says Thank You to wjones For This Useful Post:
yandaman (02-02-2017)
post #8 of 13 (permalink) Old 12-21-2008, 12:47 AM
I run 15w40 in my transmission- 5qts about every 20-25K. Put 75K on one, and it was still in great shape when I sold the truck.
DP
HIS- 93 W250 xcab LE 495k, Auto to Getrag conversion, 3.07. Hungry diesel 5x11s.
HERS 04 2500 QCSB, HO, Bully Dog, Air Dog, built auto unknown aftermarket sticks
dpuckett is offline
post #9 of 13 (permalink) Old 12-21-2008, 09:04 PM
It isn't recommended for the Getrag. Don't know why, but if you want to run MTF it works well in the NV5600.
post #10 of 13 (permalink) Old 12-21-2008, 11:12 PM
wjones's Avatar
I put the amsoil syncromesh stuff in mine and overfilled it, hasnt fallen out yet. I suppose if it does that will mean its time for an nv4500 upgrade. 85-140 regular dino in my transfer case and diffs.
, nv4500, Club Cab
wjones is offline
post #11 of 13 (permalink) Old 12-22-2008, 03:29 AM
Old 'n Rusty's Avatar
There is a good reason why lighter oils are good for the getrag. The bearings are shimmed so that there is a preload on them. Only a light oil ensures the penetration needed. Do not use gear oil or standard diesel engine oil. The reason for the over fill is that there is inadequate cooling of the pilot shaft bearings using the normal fill level. An extra quart or so of oil keeps this bearing cool under load and is said to double the life of the getrag.
91 (08-90) D250
5sp 2wd 511k VE 'adjusted', 3200 spring, Pyro, boost, 3.54 ,:thumbsup KN, 1\8" timing bump, 25mpg city 30mpg hiway 20mpg towing 6k 5'er
R60/7, Volvo 245 GL 320 k km's, f150 4x4 5 spd, MPG's are in Imp gal's
Old 'n Rusty is offline
The Following User Says Thank You to Old 'n Rusty For This Useful Post:
tanana (12-27-2009)
post #12 of 13 (permalink) Old 12-22-2008, 10:07 PM
Which is why AMSOIL's top recommendation for the Getrag is the 0W30 SSO. Good info, Old 'n Rusty.
-Chuck
