Old 10-11-2008, 09:44 PM   #13 (permalink)
I don't want to hijack the thread but I've also been thinking about a tach and naturally the Isspro would be my first choice. My truck being a 91.5 has the harness right? At least it has some sort of a harness under the dash by the fuse box that isn't being used... I think it's a 3 or 4 wire harness. I can't remember which
Also, on eguages are you referring to the harness seup they sell for like $15 to wire that in to hook to the harness in the truck?
1991.5 W250 4x4 Auto Cummins Diesel. Bone stock. Currently in the process of fixing it up before the mods come.
Richard LeBar is offline   Reply With Quote
Old 10-12-2008, 09:01 AM   #14 (permalink)
1ST GEN TECH ADVISOR
Philip's Avatar
Richard on your 91.5 look at the front of the engine. By #1 valve cover is there a 2 wire plug with the wiring going down to the harmonic balancer???
If you do not have that wiring and plug then your truck doesn't have a crank position sensor. That is needed for the Isspro or other brand tach's made to work off the factory harness.
Most 91.5's do not have the CPS on them. Some early 92's don't eather.
That would leave you with an AutoMeter alt tach or rigging up some form of sensor to trigger a tach signal for you.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, HX40/16, auto, 307's axles' B&W flatbed,
Old 10-12-2008, 09:25 AM   #15 (permalink)
Steveo24's Avatar
Auto meter
98.5 3500 2WD dually 4:10's lAuto Meter fuel, boost, pyro, and trans temp lOne piece headlights+ LED's l5 inch mitre stacks lHX 40 l150 horse Coaltrain sticks l.093 tubes l Smarty lEdge Comp HOT lStage 2 snow kit lBHAF lBD pusher pump lAmsoil, engine+diff
Steveo24 is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
