Old 09-01-2008, 03:19 PM   #1 (permalink)
whats the hp diff in intercooled and not
i have a idea on making a cooler intake charge but need some number to bounce in my head first ......
1993 hot rod standard 4x4,1993 auto stock 4x4,1993 1 ton standard 4x4,
1992 standard 2wd ,1993 standard 4x4 body beat off !!!looking for a ve pump for core !!
winkdemon84 is offline   Reply With Quote
Old 09-01-2008, 04:58 PM   #2 (permalink)
Begle1's Avatar
The intercooler adds no horsepower. It was originally added to our trucks in the name of NOx reduction.
In a performance application, it lets you make the same amount of horsepower for longer.
1990 D-250 Regular Cab: Full power screw; stout TC and A518 w/ manual valve body; ratchet shifter; piston LP; Ramcharger tank; manual off; computer-programmable 40 GPH water/meth fumigation; gauges
Begle1 is offline   Reply With Quote
Old 09-01-2008, 05:09 PM   #3 (permalink)
95whtzr2's Avatar
Really? I thought it actually made the air cooler/denser making more power... I have been wrong plenty of times before though...
Tom
2008 Dodge 3500/SRW/manual 6spd/CC/LB, B&W tob
My Photobucket
95whtzr2 is offline   Reply With Quote
Old 09-01-2008, 05:35 PM   #4 (permalink)
ok ,,, well my idea may not work then
Old 09-01-2008, 06:55 PM   #5 (permalink)
nkendall07's Avatar
Wink your truck has an intercooler right?? What were you thinking?? If you or anybody might be thinking about an air to water intercooler I think I may have come up with an idea. I work in the natural gas compression field and for those who dont know Cummins has started packaging natural gas enginges!! The point of this is that the T/A engines have a cummins made water to air intercooler that will bolt on to a 5.9 intake!!!!!!! SO the point is that I think I will be failing an intercooler on one that may accidently end up on my truck!!!!!!
93 x-cab 4x4 dually. 14mm nonwastegated exhasut housing 4 inch exhaust; fuel pin screw alomost all the way in; old smokey pin; Coaltrain custom injectors 366 spring and a grid heater gutted. Coming soon coaltrain twins!!!!YEA
nkendall07 is offline   Reply With Quote
Old 09-01-2008, 06:59 PM   #6 (permalink)
my truck is but i want a cooler intake charge ,, so i am brewing up some ideas
Old 09-01-2008, 07:02 PM   #7 (permalink)
nkendall07's Avatar
Man keep me informed always up for something new!!
Old 09-01-2008, 07:25 PM   #8 (permalink)
bulldogbones's Avatar
yes it does (make the air cooler/denser making more power) I dont know what the other guy was talking about. When he said it doesnt effect your hp. Its simple math. Lower temp air condenses there for you can fit more air into each cylinder. I always that there had to be a way to put an a/c unit in the intercooler. Kinda like giving your engine a/c. Put the cooling coils inside and there ya go ice cold air like in the winter.
06 SLT Big Horn 5.9 6spd 4" straight pipe all the way 305/70/17 Nitto Terragrappler's 1" lift front 2" in the rear about 40 Aftermarket lights
bulldogbones is offline   Reply With Quote
Old 09-01-2008, 08:09 PM   #9 (permalink)
1000EE-Monarch's Avatar
He was refering to stock HP numbers. My intercooled '92 says 160HP on the tag. A friend of mine had a non-intercooled truck (I think 1990), says 160HP on the tag. Another friend has a forklift with a non-intercooled BT5.9, tag says 165HP.
BTW the forklift engine has by far the loudest idle I've heard out of a B-series, even louder than the '01 ISB.
Alex K.
'01 3500 QC 4x4 NV5600 HO 245HP-stock for now. BHAF, no silencer ring.
WANTED: '98 12v 3500 QC 4x4 5spd 3.55 gears
1000EE-Monarch is offline   Reply With Quote
Old 09-01-2008, 08:22 PM   #10 (permalink)
95whtzr2's Avatar
Originally Posted by bulldogbones View Post
... I always that there had to be a way to put an a/c unit in the intercooler. Kinda like giving your engine a/c. Put the cooling coils inside and there ya go ice cold air like in the winter...
I remember reading somewhere that Ford was doing this for the lightning, or they were thinking about it anyways. Something where they hit a button and there would be like 45 seconds worth of cold air to use in the engine for short bursts of extra power. Seems like the numbers weren't worth it though. The regular AC would recharge the "storage tank" and you would be ready again. Like I said, I remember reading it a few years ago and never kept up with it so I don't know if they did or not...
Tom
My Photobucket
Old 09-06-2008, 12:07 PM   #11 (permalink)
ridemoto4life's Avatar
i heard about that too. never saw the new lighting come out. for any forced induction engine its a good idea but not refined enough yet
91' 1-ton SRW 4x4 LE 727 w/ LSD, Isspro gauges, 366 spring, THIN pin, pump maxed, what starwheel? BHAF, 3.5" exhaust, bagged, boostin 38lbs, Hella H4s, Borgeson shaft, PS IC.... COMING SOON! PODs, HX40 & built 727
ridemoto4life is offline   Reply With Quote
Old 09-06-2008, 01:03 PM   #12 (permalink)
Cummins Crazy
Cummins6speed's Avatar
Yes intercooler's will add horsepower by cooling the intake air making the air more dense and it will also reduce your egt's
My truck: 06 5.9 G56 4x4 Quad Cab Short Bed Patriot Blue. Smarty TNT, Valair 3600DD, DiPricol's, Home made intake w/ amsoil filter, Straight Piped w/ 7" tip, silencer ring MIA, glove box sticker MIA
IBEW 551
Cummins6speed is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
