cummins man
Shift Kit???
I've really thought about gettin a shift kit for my truck... I've heard it will help save your tranny ...Is it worth the money? how hard is it to install? if anyone has one, let me know how you like it. I've also though about gettin a better torque convertor...I've heard the stock ones can only hold up to about 240 hp or so...
Black 92' Cummins, Intercooled, auto, Bully Dog fuel pin with washer removed, Full Power screw: around 2 turns, smoke screw:3 1/4 turns, AFC Starwheel:almost 1/2 turn, stock turbo and injectors for now, straight piped, ASA Modified cold air intake with AFE filter, Isspro boost and pyro gauges, Trail Mark M/S Radial tires, 229K and rollin...
#2 (permalink) |
As for the converter, My money is on hughes. They reman your converter in a weeks turnaround time ussually. Trans-go makes a great kit. Not to bad to install but if you're only an oil-changer/battery swaper it's not the job for you. Or call DTT and get a valve body and a converter in one place.
2006 3500 Mega Cab CTD 4X4 Auto SRW 91.5 CTD on the Floor /Engine Only |
#3 (permalink) | |
1ST GEN TECH ADVISOR
![]() I have used Transgo, B&M, and a couple of brands off the market now. Most do the job well. Like CP was wondering is. What is your mechanical ability. It isn't a drop in affair. You do need some mechanical knowledge. TransGo does have a decent set of instructions.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, HX40/16, auto, 307's axles' B&W flatbed, |
#4 (permalink) |
Just get a valve body already built..
06 Crew Cab, 4x4, Goerend Full Billet 48RE, 6.5' bed, level kit, 5" T.B Magnaflow, K&N big tube intake,Silver 64,Studded (625's), Big Stick(s),G.D.P belt L.P,Smarty Revo/tnt., Gauges, 3:73 ratio diffs., non-slip rear diff. Lead Foot. 2-2009 Silver Q.C 6.7 3:73 4x4 6.5' bed Stock ..... |
#5 (permalink) |
Just get a manual valve body already built. Although they're harder to find and more expensive for the overdrive transmissions than the non-overdrive transmissions.
1990 D-250 Regular Cab: Full power screw; stout TC and A518 w/ manual valve body; ratchet shifter; piston LP; Ramcharger tank; manual off; computer-programmable 40 GPH water/meth fumigation; gauges |
#6 (permalink) |
cummins man
Well my dad is a mechanic so he knows what he is doin, I've learned a lot from him and i know quite a bit, but not as much as him, but i think we could put it in...
