Old 08-30-2008, 11:35 AM   #1 (permalink)
proffesional bs'r
plowboy1138's Avatar
marine injectors in a first gen?
i have came across a set of 370hp boshe marine injectors cheap....does ne one kno if they will go in a first gen ok or what needs to b dun to put them ina first gen bfor i start taking my truck apart
andrew stein, 92 D350 47rhauto banks flexplate, gorend tc, transgo kit drw pyro&boost gauge 40+boshe injectors fuel pin ground and turned with the smoke screw turned all the way in full power screw, holset hx40 WHEN I GROW UP I WANNA B JUST LIKE BEER PLAY
plowboy1138 is offline   Reply With Quote
Old 08-30-2008, 12:26 PM   #2 (permalink)
cumminspride's Avatar
The only usable parts are the nozzles and pintles. You can swap nozzles from them to your 1stgen injector body but they may not pop correctly. I would at least try it if you have the injectors already.
2006 3500 Mega Cab CTD 4X4 Auto SRW
91.5 CTD on the Floor /Engine Only
cumminspride is offline   Reply With Quote
Old 08-30-2008, 03:40 PM   #3 (permalink)
proffesional bs'r
yea i got em for free at work lol
Old 08-30-2008, 03:43 PM   #4 (permalink)
proffesional bs'r
if i was to runa p-pump, would i b able to run those injectors as they r
Old 08-30-2008, 07:25 PM   #5 (permalink)
Upstate Bombers VP
PToombs's Avatar
If you change the timing cover, IP, lines, and a bunch of small stuff!
The angle of the holes still won't be quite right for the pistons, as I understand it.
If you really want to try them, take your injectors and the 370's to the fuel shop and have them swap the nozzles and set the pop pressures for the VE.
If you buy a set of 370's from New Era or someplace, they are all set to use in a 1st gen.
Pete
'92 D350, sticks, air, pipes, 388 hp, 789tq
PToombs is offline   Reply With Quote
Old 08-31-2008, 03:38 PM   #6 (permalink)
First Generation Moderator
Greenleaf's Avatar
They are 81.00 a piece just for the tip. If you got 'em free your very lucky. They will flow nearly as much as the Lucas tip (POD)
1990 D250/1992 D250 Modified by **Smokehouse Diesel** Ashland, OH
....therefore, my brothers, I want you to know that through Jesus the forgiveness of sins is proclaimed to you. Acts 13:38
Greenleaf is offline   Reply With Quote
Old 08-31-2008, 03:44 PM   #7 (permalink)
proffesional bs'r
yea got em off a pullin rig that put a rod thru the block....i gotta hx55 and a nv4500 and south ben 3600 off this same rig
im thinkin of convertin my first gen to a nv4500 also
Old 09-12-2008, 06:23 PM   #8 (permalink)
BIGrusty250's Avatar
i'd say you lucked out on that deal.
92 250 2wd 5spd, 230 pump, 100 horse injectors currently, hx50 and 6 inch stack setting on the bench, time to save save save for a clutch!!!! .
BIGrusty250 is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
