NEED HELP twin question
i no i no i ask alot of questions but there not for nothing trust me ![]() i can get a HT4C cheap ... would any one no if a hx-35 in top of a ht4c would be a good working set of twins ???? ... or is a ht4c two big. i am looking for 400-450 hp ,
1993 hot rod standard 4x4,1993 auto stock 4x4,1993 1 ton standard 4x4, 1992 standard 2wd ,1993 standard 4x4 body beat off !!!looking for a ve pump for core !! |
#2 (permalink) |
proffesional bs'r
no idea but i have a sumilar question of how bout a stock h1c over a hx55.....i kno sumone has had to have dun twins a first gen
andrew stein, 92 D350 47rhauto banks flexplate, gorend tc, transgo kit drw pyro&boost gauge 40+boshe injectors fuel pin ground and turned with the smoke screw turned all the way in full power screw, holset hx40 WHEN I GROW UP I WANNA B JUST LIKE BEER PLAY
#3 (permalink) |
seeker1056 has an HX35 over HX55 in his puller. Got a funky hot pipe though? I can honestly say that the HT3B under an H1C is a nice set of twins. I had a H1C in a 12cm gated housing over an HT3B in a 26cm non gated open throat housing and it spooled great! By the time I hit 25psi It seemed like it shot to 55 and I was gone! Loved them. They were on my 91 1/2 W350. I fueled them with a set of 6X.016 EDM's and the stock 12mm IP.
2006 3500 Mega Cab CTD 4X4 Auto SRW 91.5 CTD on the Floor /Engine Only |
#4 (permalink) |
Admin
I have a 35 over the HT3B. The 35 by itself was putting out 36 psi before I had the twins installed. After the install, I can feel the 3B lighting off around 18 pounds of boost. I'm running about 400 HP depending on what set of injectors I have installed. The 35 has a 12 wastegated housing, set to open around 28 PSI. I put in a set of New Era 435's last weekend and I'm running about 58 pounds of boost on a hot afternoon so it will be over 60 on a cool day. I get smoke at take off until the boost comes up and then it hazes but no heavy smoke. I'm also running water/meth which helps with the smoke. The setup is made for towing and works pretty good. I'm still in the high 14's and low 15's in the 1/4 mile. Takes off and runs the first half hard but then sorta settles down and doesn't finish hard. Just bought a 05 Chevy so at this point I don't know how long I'll keep the 93. have a race next weekend at Eureka, finished second last year in the auto class, need to get first this year!(bracket racing)
Stan 93 D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust, modified tranny, EGT/boost/tranny/tach gauges, TPS removed, a little chrome under the hood. Mag-Hitec tranny and diff. covers. Rear sway bar. Line-x bed liner, after market seats. Front end rebuilt with new springs - 2 " taller now. Single stage Water/Meth system installed. Oversized intercooler w/3" IC lines. 05 Chevy 2500 HD, Duramax W/Allison, 17" Hummer wheels w/285-70-17 BFG's, modified air box, ported turbo mouthpiece. Predator programmer. |
