Old 08-25-2008, 09:38 PM   #25 (permalink)
cummins man
92 smokin blacky's Avatar
sweet! thanks for the info! i might have to look in to these injectors a little more!!! yeah you are braggin them up!!! they sound pretty amazing! and it seems like your pump probably isn't turned up quite as much as mine... except for the full power screw you got turned almost all the way in... but you got the injectors and i'm sure thats the big difference... I have really enjoyed my pump turnup...but this is as far as i am gonna go for now...i don't wanna blow my tranny, but i think it will hold for awhile... those injectors are gettin me thinkin... i always have to add things to get little more power, it keeps it more fun that way!
Black 92' Cummins, Intercooled, auto, Bully Dog fuel pin with washer removed, Full Power screw: around 2 turns, smoke screw:3 1/4 turns, AFC Starwheel:almost 1/2 turn, stock turbo and injectors for now, straight piped, ASA Modified cold air intake with AFE filter, Isspro boost and pyro gauges, Trail Mark M/S Radial tires, 229K and rollin...
92 smokin blacky is offline
Old 08-26-2008, 04:24 AM   #26 (permalink)
First Generation Moderator
Greenleaf's Avatar
[/quote]
Not to argue but why would you want to have to modify your pump just to run an injector I would rather just get an injector that works woth my pump!!? [/quote]
[/quote]
How dare you tell me to run a stock injector kiss my A$$ [/quote]
Because you asked, silly. It's in print. Go back and read what you typed.
Please keep it civil as I don't like to have to edit /delet anyone's posts.
From what I have read, you still have not given the specs on the Coaltrian Injectors. If you don't know, that is fine. I can give the specs on the PDR-POD's and would be helpful to compare the design of the two.
GL
1990 D250/1992 D250 Modified by **Smokehouse Diesel** Ashland, OH
....therefore, my brothers, I want you to know that through Jesus the forgiveness of sins is proclaimed to you. Acts 13:38
Greenleaf is offline
Old 08-26-2008, 05:25 PM   #27 (permalink)
cumminspride's Avatar
Does Coaltrain cut their own? I hear alot of good reports on them but I am curious as to what they are too.
2006 3500 Mega Cab CTD 4X4 Auto SRW
91.5 CTD on the Floor /Engine Only
cumminspride is offline
Old 08-26-2008, 07:41 PM   #28 (permalink)
nkendall07's Avatar
Yes they do cummins they can cut just about anyhting you want I believe.????
93 x-cab 4x4 dually. 14mm nonwastegated exhasut housing 4 inch exhaust; fuel pin screw alomost all the way in; old smokey pin; Coaltrain custom injectors 366 spring and a grid heater gutted. Coming soon coaltrain twins!!!!YEA
nkendall07 is offline
Old 08-26-2008, 07:49 PM   #29 (permalink)
6LCummins
Posts: n/a
wat part of he dont know dont u understand greenleaf??? he likes them they are better than PODs in his opinion. nuff said. ive heard great things bout richard and i would buy from him if i didnt have connections already. and on a side note my stock pump put out way more than it should have on a dyno and with 190s did quite well too.
Old 08-26-2008, 07:58 PM   #30 (permalink)
Richie Osgood's Avatar
Relax, breath in,,,,,,,, breath out.. I feel better already.
89 dodge 3/4 4x4, A727 ,3.07 gears, factory L S , powerstroke intercooler, S300, stans exaust with stainless tailpipe, fuel power screw turned?, fuel pin turned to deepest, 3 turns smoke screw, 1/2 turn down on starwheel. 93 W250 extended cab, stock with rag.
Richie Osgood is offline
Old 08-27-2008, 04:57 AM   #31 (permalink)
Greenleaf's Avatar
It would seen odd IMHO, to purchase a product and not know what it is much less recommend it to others. I would HAVE to know what it is all about/specs etc. These may be really good injectors but some folks want to know........
On a positive note, I know Mark @ Coaltrain Diesel performance personally, and he PM'd me about these. I will post up any and all information he can provide.
GL
Old 08-28-2008, 05:59 AM   #32 (permalink)
Greenleaf's Avatar
I'm not getting too far with this. Mark, @ Coaltrain Diesel told me that his injectors are a new, custom cut, original. Made to the customers specifications................ so there you go. A customer must specify what to cut, becasue they are not yet cut.
What of this doesn't seem on par? (the customer doesn't know what he ordered yet recommends them to others)
One thing he cleared up is the fact the injector are set to factory specs in terms of pop-off pressure so the pump time would NOT come into play as much as a very high setting like, say, POD's.
I still don't know what brand they are say Bosch or Lucas etc.
Old 08-28-2008, 07:19 AM   #33 (permalink)
Administrator
Evil Twin's Avatar
you don't need to talk to him or anyone else like that, and we will not stand for it ....GOT IT ??
2001 4X4 Q-cab Sport black, full billet DTT trans, billet F-plate Mach 7's, B1-B2 twins, Blue Chip Special X VP, Adrenaline, studded & O-ringed, BD-RAD,Flex-A-Lite electric fans, Autometer Gages, Egt, Boost,Fuel, Oil &,drive pressure, trans temp, RASP, Big line kit, Track bars 2" leveling kit, 271 T-case, DSS, 3rd gen trac bar 623 HP 1175tq with old set-up
Evil Twin is offline
Old 08-28-2008, 03:49 PM   #34 (permalink)
Coaltrain Diesel Performance
wtfd6's Avatar
wow everyone calm down a tad! Greenleaf is a very knowledgeable guy when it comes to First Gen trucks!
Our injectors are set to the factory specs. They are new tips installed in original Bosch bodies. I get tips custom cut and install them into core bodies myself!!! that way all the opening pressures are within my tolerance levels.
We do not cut our own injectors. There are only a few places around that actually do EDM work.
nkendall asked for an injector that would work well for towing with the stock turbo so that is what we provided.
anybody with questions feel free to pm me.
2000 Ram3500
Mark 419-392-1678
Full line of diesel repair and performance items. Custom injectors, turbos, injection pumps, gauges and much more!
coaltraindieselperformance.com
Proud Member Of The Ohio Coal Rollers
wtfd6 is offline
Old 08-28-2008, 03:59 PM   #35 (permalink)
nkendall07's Avatar
Look this is the most rediculus arguement that I have ever had the oppurtunity to be a part of!! This started out as me wanting to brag on a company that did a great job for me and like always if someone does a good job for me or anyone I know I want to brag on them. In turn if they had done a bad job I would have been on here doing just the opposite!! If the answers that I gave to GL did not satisfy him then I am sorry but there was no need to have him take it to what I felt like was insulting me so this is done lets move on!!!!!
Old 08-28-2008, 04:15 PM   #36 (permalink)
Super Administrator
BBRam's Avatar
The only one here that insulted anyone was you NK. If an explanation to how things function is insulting, I'm not sure what to tell ya.
03-3500, DRW, QC, 4x4, DTT Trans, Mag-Hytec, R700 BD Twins, BD IC Boots, BD Billet Flexplate, Lockup Switch, SMARTY TNT-R BETA/TS MP-8, Eliminator Fuel System, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. Old #'s (R/T .021, 60' 1.76, 1/4 ET 13.14 @ 100.45 mph)
BBRam is offline
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
