#26 (permalink) | |
You shouldn't have to stop except to keep your hand from jumping around ( after all - these trucks DO ride so smooth ![]() ![]() )
'93 D250 CC auto, 18.5cm w/30 psi, 366 spring w/1 turn clipped, power screw bottomed-backed off 1 turn, modified Ol Smokey's power pin, smoke screw fully out, hat modified to get pin higher - still smokes, '94 trans w/clutches and some hard parts, 4510 w/4 1/2" intake and heat shield, grid htrs mia, 4" dp into 5" pipe to single 5" stack, 285's rear 265's front |
#27 (permalink) | |
92 d250,5" turn out stack,smoke screw 4 turns,full power screw 3/4 turn,bhaf,boost gauge.....other stack coming soon |
#28 (permalink) |
Just thought of one other thing ---- You did connect the center wire from the TPS connector to the center terminal on the pot ???? The outside connections don't matter but that CENTER one must remain the center.....
#29 (permalink) | |
#30 (permalink) | |
#31 (permalink) |
Yes, nearly all have about a 270* - 300* rotation. Find the approximate middle - hold the connections at the bottom and turn the shaft to about 12 o'clock. That gave me about 35 mph into 3rd and 38 mph shift into OD with light throttle. Then turn it just a little and the OD should kick in later. IF it kicks in about the same, turn the shaft the other way. 1 more thing I just thought of : IF I turn my shaft the wrong way then try to set CC, the cruise accelerates like it's trying to catch up to the 'accelerate button'....Clear ? Like you set the CC at 45, tap the brakes, then hit resume. The CC accelerates to 45 again. But if you keep hitting the 'accelerate' button before you reach 45 then the CC will constantly try to catch up.....
#32 (permalink) | |
#33 (permalink) |
well i cant seem to get it to work right ![]() iv tryed putting it in the middle and turn it one way a little bit and then the otherway a little bit and nothing right now where its set if i floor it it goes from first then around 20 it goes hay wire and ends up going into od or so it feels like
#34 (permalink) |
Well darn, must be time for a toggle switch then.
1990 D-250 Regular Cab: Full power screw; stout TC and A518 w/ manual valve body; ratchet shifter; piston LP; Ramcharger tank; manual off; computer-programmable 40 GPH water/meth fumigation; gauges |
#35 (permalink) |
First Generation Moderator
I didn't read through all this but I'll ask......... Do you know that the TV and TV control cable is operating properly and properly adjusted? I couldn't stands it no more and had to change the thread title....... It's all good.
1990 D250/1992 D250 Modified by **Smokehouse Diesel** Ashland, OH ....therefore, my brothers, I want you to know that through Jesus the forgiveness of sins is proclaimed to you. Acts 13:38 Last edited by Greenleaf : 08-27-2008 at 05:57 AM. |
#36 (permalink) | |
tryed adjusting it again on the way to work still no difference
