Old 08-21-2008, 06:54 PM   #13 (permalink)
John Deere Matt's Avatar
what is this mod? were is it suposed to go and what exactly does it do?
2006 2500 Cummins quad cab long box afe stage 2 intake, quadzilla boost fooler, and smarty.looking for more
also have a 1992 w250 turned up and a tighter exaust housing on the turbo
John Deere Matt is offline   Reply With Quote
Old 08-21-2008, 07:34 PM   #14 (permalink)
Here is some reading material for you from the sticky on the dieseltruckresource.com. The pot allows you to dial in your O/D shift points to your liking. There is 2 more threads in the sticky talking about O/D by putting a 3.0 liter V6 TPS on and using governor pressure.
Installing a Potentiometer in place of the TPS - Dodge Diesel - Diesel Truck Resource Forums and Super Cool and CHEAP TPS fix! Dial-in your OD shift point! - Dodge Diesel - Diesel Truck Resource Forums
91.5 W250 rusty p.o.s., pods, no afc, pull cable, AM electric FP gauge, Isspro boost, pyro, 366, 91 W350 parts truck, (SOLD) 92 W250,
OHIO Coal Rollers
921stgen is offline   Reply With Quote
Old 08-25-2008, 11:14 AM   #15 (permalink)
matj1990's Avatar
my tranny shifts from 1st to second fine 3rd kicks in around 30 realy light foot around 20 and then od kicks in bout 1 second after 3rd no matter what speed you guys think this mod will fix that? i have a 0to60 time of 12 seconds pretty much skippin 3rd hoping to see a big diff with this mod
92 d250,5" turn out stack,smoke screw 4 turns,full power screw 3/4 turn,bhaf,boost gauge.....other stack coming soon
matj1990 is offline   Reply With Quote
Old 08-25-2008, 04:33 PM   #16 (permalink)
matj1990's Avatar
well i did the mod and its not affecting anything ive turned the pot both ways and it didnt seem to make a difference
Old 08-25-2008, 04:47 PM   #17 (permalink)
matj1990's Avatar
but it has to be making a connection because if it wasnt wouldnt it not run or work at all
Old 08-26-2008, 06:18 AM   #18 (permalink)
matj1990's Avatar
anybody??????
Old 08-26-2008, 08:18 AM   #19 (permalink)
unixcowboy's Avatar
How far did you turn the pot ???
I adjusted mine with it hanging under the dash at first so I'd have easy access. When I found out I was close, I drilled a hole in the dash and mounted it with the working setting at 12 o'clock. Then I fine tuned it. Now 11:30 it shifts at 35, 10:45-10:55 it shifts at 45, 10:00 it shifts at 55, 9:00 it doesn't shift - at least not up to 70.
I found that a little makes almost no change - if you watch close maybe 1 - 2 mph...
Then you turn it and turn it and turn it - a little each time and all of a sudden it makes a big difference...
From working good to not working is like from 10 o'clock to 2 o'clock...but from 2 o'clock to 12 o'clock is very little change.
'93 D250 CC auto, 18.5cm w/30 psi, 366 spring w/1 turn clipped, power screw bottomed-backed off 1 turn, modified Ol Smokey's power pin, smoke screw fully out, hat modified to get pin higher - still smokes, '94 trans w/clutches and some hard parts, 4510 w/4 1/2" intake and heat shield, grid htrs mia, 4" dp into 5" pipe to single 5" stack, 285's rear 265's front
unixcowboy is offline   Reply With Quote
Old 08-26-2008, 09:37 AM   #20 (permalink)
matj1990's Avatar
well i can have it all the way one way and it makes no difference when i turn it all the way the other way?
Old 08-26-2008, 10:21 AM   #21 (permalink)
unixcowboy's Avatar
You're driving the PCM nuts giving it the extremes.
Try finding the center - roughly.
See how it drives.
Move it SLIGHTLY one direction then drive it again.
You should notice something by the time you move it 1/8 turn, if not try the other way - SLOWLY....
Old 08-26-2008, 11:00 AM   #22 (permalink)
matj1990's Avatar
See how it drives.
ok will try that i feel like a dumm workin right now so wont be able to try it for a while
Old 08-26-2008, 11:01 AM   #23 (permalink)
matj1990's Avatar
when i try it do i stop completly leave it running adjust it try it again ? or do i shut it off start it and do it that way ???
Old 08-26-2008, 11:48 AM   #24 (permalink)
Begle1's Avatar
If it's giving you that many problems, you can always put it on a toggle switch.
1990 D-250 Regular Cab: Full power screw; stout TC and A518 w/ manual valve body; ratchet shifter; piston LP; Ramcharger tank; manual off; computer-programmable 40 GPH water/meth fumigation; gauges
Begle1 is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
