Old 08-12-2008, 10:21 PM   #1 (permalink)
gear jammer 91"'s Avatar
wich turbo should I buy?
I know I just asked a loaded question, but I need help deciding. Two turbo's are out of the question, my pocket
book can't support that kinda power. My truck should be in the neighborhood of 300hp, and right now with my baby H1C and a 16cm turbine housing I'm hittin 32psi+/- and 1400 degrees (1500+ without the w/m) I need to get my egt's down and I would like to get my boost up closer to 40psi. Right now I can spool my turbo pretty easily, but when I have to detune for mileage it gets kinda laggy. I've been looking at either a PDR hx-40, a S300, or a HX 35/40 hybrid with a 14cm turbine housing. My concerns are,
1. turbo lag, I would like to at least keep it the same if not reduce it.
2. egt's, I don't want a turbo with too small of a turbine housing, (12cm)
3. upgrade ability, I don't want to be shooting my self in the foot by buying the wrong turbo for bigger stick's, or whatever else I think I need down the road.
I asked for it, so let me have it. Help me decide witch turbo is right for me. Thanks in advance.
91 now intercooled W250, 1/4 from runaway, AFC lever MIA, 366 spring, BHAF, piston lp, PDR HX-40, 4"straight piped, W/M, egt, boost gauge, timed to the head, 270K+ and a getrag, KDP tabbed 402HP 865TQ on meth
gear jammer 91" is offline   Reply With Quote
Old 08-12-2008, 10:29 PM   #2 (permalink)
well i can let u no what a hx 35 is like putting one on next week .
1993 hot rod standard 4x4,1993 auto stock 4x4,1993 1 ton standard 4x4,
1992 standard 2wd ,1993 standard 4x4 body beat off !!!looking for a ve pump for core !!
winkdemon84 is offline   Reply With Quote
Old 08-13-2008, 05:38 AM   #3 (permalink)
1ST GEN TECH ADVISOR
Philip's Avatar
Well Item #3 rules out the hybred turbo's. Remember they are a 3" exhaust outlet. If your thinking about pushing some power somewhere along the line your going to run into the 3" barrier for air flow.
The stick shift trucks seem to like smaller exhaust housing. The S300's are listed with 12 or 13cm housing. This would keep your lag down and not hurt in the drive pressure department.
The HX40 would spool just a little slower than your maxed out H1C, but it wouldn't spool that much slower.
Here is a link with a little reading in it on HX40's. Pay attention to MMillers posts. His truck is a stick shift. I have ridden in it before.
1stGen.org :: View topic - HX-40's???
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, HX40/16, auto, 307's axles' B&W flatbed,
Old 08-13-2008, 09:38 AM   #4 (permalink)
mtm93ramnasty's Avatar
i have an hx35 on my truck im pushing 43lb of boost my egts max out the pyro (1500) with my mods. I would say go with the hx40
93 ctd pump maxed, timing, fuel pin ground flat, gov spring, 6x18s, CoolerTubz, southbend con fe, isspro guages boost-pryo-fuel pressure 340 739 stock lp no ksb hotwire
to come air dog, sps62,rust removal, new bed, paint
mtm93ramnasty is offline   Reply With Quote
Old 08-13-2008, 05:26 PM   #5 (permalink)
I read that one yesterday. I like MMillers results, and the hx-40's do have the best price. I just wanna be sure cause I don't have a lot of cash too play with.
Old 08-13-2008, 06:49 PM   #6 (permalink)
Richie Osgood's Avatar
Ive said it before and I will say it again. My basic S300G is a nice little turbo. Its a 57mm and 14 hot side. Its gated at like 32 and unplugged it goes to 35 with my current settings.
89 dodge 3/4 4x4, A727 ,3.07 gears, factory L S , powerstroke intercooler, S300, stans exaust with stainless tailpipe, fuel power screw turned?, fuel pin turned to deepest, 3 turns smoke screw, 1/2 turn down on starwheel. 93 W250 extended cab, stock with rag.
Richie Osgood is offline   Reply With Quote
Old 08-14-2008, 05:22 AM   #7 (permalink)
Philip's Avatar
Richie the S300' are good from what I have seen many people post about them.
What I don't like is the venders going sky high on prices for them while the feeding frenzy is on. When I was trying to decide on a turbo a while back. Most of the venders didn't even want to talk about holset's. All they wanted to push was the S300's for $500 more. The price has went up sence them on the S300's. For some reason the HX40's haven't went up much at all. I wonder why? The most likely reason is there are many places selling holset's. So finding a good price is easyer. How many places are selling S300's. Only a hand full of places list them moded for Dodges.
Old 08-14-2008, 05:34 PM   #8 (permalink)
PDR has a decent pricce on the s300's. My concern with buying an s300 would be that the turbine housing would end up being too restrictive for towing with the fuel turned up, and too restrictive if, I upgraded injectors. I really would like faster spool up, but I'm not willing to sacrifice egt's to get it. PDR claims their HX-40's spool like they have a smaller turbine housing's. If anybody has had any experience with their turbo's it would be great to hear what they have to say.
Old 08-14-2008, 06:47 PM   #9 (permalink)
YA.. mine is the stock unit not the pricey one. I got it from a local cummins dealer. That is the turbo the shop is using for an upgrade unit replacing hx35's on second gen trucks. I would have liked the 62 or 64 compressor unit but they were out of my price range. I am not sure of the map range or the hp range but it is nice at my current settings.
Old 08-15-2008, 05:03 AM   #10 (permalink)
Philip's Avatar
Anyone selling S300's won't give you a map chart I asked.
The PDR HX40 is the Super HX40 other venders list.
A HX40/16 will spool almost like your H1C with a 16cm. I see very little difference between my HX40/16 and the HX35/16 I removed on spoolup.
With the fuel mods your listing you can spool a HX40.
Old 08-15-2008, 07:14 PM   #11 (permalink)
Thanks for all the info guys. I think I'm gonna go with the pdr hx-40 and use the money I save to buy the required 4" down pipe. I think that would be my best bet for the power I want while still keeping the egt's safe.
Old 08-30-2008, 06:27 PM   #12 (permalink)
I bought the PDR 40' got it on last night, so far so good. It whistles good and loud, and my egt's went from around 1400 with the baby H1C-16 and W/M. Now The highest I've seen is around 1200, and thats with the W/M off. Now all I need is an adjustable boost elbow, the waste gate is opening at 25psi, and I want it more like 40.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
