4BT Injection Pumps - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 10-13-2013, 05:16 PM Thread Starter
1972RedNeck's Avatar
4BT Injection Pumps
I went to a meeting at the Fire Hall today and afterwards I took a snoop out back. Setting along the building, they have a 4BT powered generator. The injection pump is one I have never seen.
The pump had no aneroid device and was quite small. It was a rotary pump. I couldn't see any tags.
The 4BT in our 9350 MacDon has an "A" pump, the 4BT in Dad's Chevy has a VE, and I have seen quite a few "P" pumps. It is definitely none of the above.
What other pumps did 4BT's come with?
"they put 6.0's ambulance's. long story short, people died..."
1990 F350 4X4 E4OD 4BT Fast
1993 W250 G360 6BT Getting Faster
1972RedNeck is offline
post #2 of 5 (permalink) Old 10-13-2013, 05:46 PM
dB Zac's Avatar
Try the 4bt swap forums
Zac Soares. 92 Dodge Ext Cab M/T Dually,Super B 57/64/14, BHAF, 2nd gen intercooler, Denny T stage 1 pin,Pump turned up a bit, 366 gov spring, timing spacer, 5X12 sprayers, 4" exhaust, 350HP clutch.
dB Zac is offline
post #3 of 5 (permalink) Old 10-19-2013, 08:10 AM
sas_silverado's Avatar
It could be a cav pump, engine was most likely non turbo
93 2wd ext cab lb getrag, 400hp valair, he351cw,
08 ccsb 6.7 firepunk efi live cps5,dpf/egr deletes, new welding rig!
sas_silverado is offline
post #4 of 5 (permalink) Old 10-19-2013, 09:33 PM Thread Starter
That's what it is. The motor has a turbo. Can you tell if it had a factory turbo?
post #5 of 5 (permalink) Old 10-20-2013, 09:31 AM
Ducati M.
DMan1198's Avatar
The only way to tell if it was turbo'd is pull the pan and see if there's oil sqirters for the pistons
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM w/MCC, OD, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan,
v2 Finally doing stuff
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
Instagram:
DMan1198 is offline
