» Site Navigation
» Network Links
View Poll Results: What kit would you buy?
AEM Meth Kits
10.00%
Snow Performance Meth Kits
18
90.00%
02-19-2013, 04:31 PM
#1 (permalink )
VA Chapter President
AEM or SNOW Meth kits?
On the fence of what one i want to buy. I have heard AEM has gotten allot better with there pumps and fittings.
92 W250//DAP 5x16's//62 HTT HTB2//Denny 1//4inch Diamond Eye//33's Nitto Terra/Fuel/Trans/Boost/EGT//KDP//TRE Trans//DDT converter 1200stall//TRE custom valve body//Borgeson Shaft//ARP studs//TRE O-Ringed//60lbs springs//Scheids 12MM IP//Air dog 2 165GPH//XDP Fuel Sump//Snow Stg2//CPP Traction Bars//Timing to the head// 418HP 780TQ
02-19-2013, 06:41 PM
#2 (permalink )
I have a Snow kit and it seems well built. Never had any problems and no leaks ect. so far. I don't have any experience with AEM.
'92 w350 5spd- VGT, 5x12's, 366, M&H spacer, Snow stg 2, BHAF, gauges, 4" TBE, VE adjustments, otherwise stock
02-19-2013, 06:49 PM
#3 (permalink )
David
Original owner of a plain'ol VE fueled '93 W250 ClubCab. Green
02-19-2013, 06:54 PM
#4 (permalink )
02-19-2013, 08:25 PM
#5 (permalink )
Originally Posted by
BC847
I like their CMGS progressive controller
since it could fit in my 4 gauge dash pod. It would be alot easier than having to pop the hood and adjust it.
02-20-2013, 01:56 PM
#6 (permalink )
Moderator
I have a Devils Own kit also , the price was better than the others.
92 D250 custom made bed, 190 inj., 16cm , electric cooling fan, 2nd gen air horn, 5spd., Dana 61 3.31 gears, 1 stage W/M set up
97 2500 4X4 auto DDP 40 HP injectors, no 8 fuel plate, homemade 3" intake horn, BD converter, BHAF, electric cooling fan
02-23-2013, 05:48 PM
#7 (permalink )
Still debating, I'm really looking for cooler EGT right now
02-23-2013, 07:58 PM
#8 (permalink )
Cooling mist
02-24-2013, 10:55 AM
#9 (permalink )
Cooling mist does look nice. How well does the gauge work for settings? And would you rate this company high quality?
02-25-2013, 05:31 PM
#10 (permalink )
Went with snow stage 2 kit. Will post once installed
03-02-2013, 07:35 AM
#11 (permalink )
Install was fairly simple. Just need to get things dialed in. What do you all run your start PSI at and full PSI at?
04-21-2013, 07:58 PM
#12 (permalink )
Bump...how'd ya end up liking the snow stage 2 kit??
Linear Mode
