Installing 2nd gen piston pump, do i need to add a spacer? - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 03-12-2012, 07:41 PM Thread Starter
Shakes's Avatar
I'm installing a stock 2nd gen piston lift pump i got from geno's garage. Do I need to add a spacer to that pump when installing it on a first gen?
W250, Compounds s472 over s362 62/65-12, THD comp 83lph injectors, 60#'s, ported and O ringed head, dps 3 pc manifold, 366 spring, M3 pin, Front and Rear Lockers, 4.10's, cross over hydro assist hi steer, custom lift w/44" Super Swampers!!!
Shakes is offline
post #2 of 9 (permalink) Old 03-12-2012, 08:01 PM
cstalnaker's Avatar
IF it didn't come with one, then probably.haha You can buy the spacer, when I got my LPPP, I bought it in a kit and it came with everything. But, I believe the spacer is like 1/4in. or something close.
1992 rcsb, flatbed, hotrod 12mm VE by Mountaineer Diesel, marine pistons, ARP studs, HX35/HT3B compounds, full 5in. exhaust, 47rh...
cstalnaker is offline
post #3 of 9 (permalink) Old 03-12-2012, 08:23 PM
cumminshp's Avatar
Yes im running a second gen lift pump i set up everything myself. You will need a spacer and you will need to make/bend one line and also regulated it, because they can put out 50+psi and you dont want anymore then about 18psi on a first gen but i would regulate at least a bit lower.
93,w250 EC,3.54s,timing bump,pump tuned,CAI,tabed,6 autometer gauges,57/65/14,4''-5''mitre stacks,built trans,cpp 7x10s,dennyt stge 2,plp,6''lift 35''/16's. 97 eclb standard swap and build in the making.
cumminshp is offline
post #4 of 9 (permalink) Old 03-12-2012, 09:12 PM Thread Starter
Shakes's Avatar
Yeah I've got the regulator mounted up. Just finished trimming the lifter cover insulation. Now gotta drop the tank and install the larger fuel lines. Gonna have to round up a spacer tomorrow now.
Shakes is offline
post #5 of 9 (permalink) Old 03-12-2012, 09:32 PM Thread Starter
Shakes's Avatar
Also can anyone tell me for sure how thick the spacer needs to be??
Thanx.
Shakes is offline
post #6 of 9 (permalink) Old 03-12-2012, 10:31 PM Thread Starter
Shakes's Avatar
Upon further research the spacer is 1/4" thick and is cummins part # 3914284. Supposed to run about $12us. If I can't find one up here I might just plasma cut 2 sbc fp adaptors and throw a gasket between them.
Shakes is offline
post #7 of 9 (permalink) Old 03-12-2012, 11:57 PM
cumminshp's Avatar
1/4" thought i said that before sorry. Also i didn't run larger lines mines doing great just fine and fp never drops. That's up to you though, good luck if you got any other questions for me just ask.
post #8 of 9 (permalink) Old 03-13-2012, 01:46 AM Thread Starter
Shakes's Avatar
I totally read past that sorry. Ive got all the stuff left over from past racecars to build the fuel lines full 3/8" feed and return plus a 3/8" draw straw. Figured I'd put it to use on this truck.
Shakes is offline
post #9 of 9 (permalink) Old 03-13-2012, 02:24 AM
cumminshp's Avatar
Ya can't hurt i would of if i had extra material laying around but i didn't and other people have been fine and this is more then enough, im only running about 7psi because i bought a cheap regulator but its enough but ill upgrade later and the fuel lines as well, still though i don't think im loosing power.
