im new here to the ve trucks, i have a very potent 24v and a mild 12v, but working on a buddy of mine's ve truck and hes looking to get 500 or over to do some local pulling with us, and well to just have some fun..... ive allready got the turbo and downpipe, know im doing to do and exhaust manifold headstuds, intake plate, and putting my old 24v intercooler in it, oh yea its a stock non intercooled truck to start with, basically i was wondering about the fuel upgrades, what will be needed to be done to the pump and what are some good injectors that i could run.... any help woulld be appreciated, from one cummins lover to another
500 on a VE is possible, but tough. Is he ok with 400? That's easier
1989 D250 2wd Scheid 14mm VE pump, 5x25s, Air Dog II, Majestic Turbo 62/65/14 S300 w/internal and external gates, NX two-stage. 47RH with transbrake built by J&H Performance. 487 on fuel, 972 on the jug.
yea 400 would be a good start, he want to be competitive arround local, what about with a different pump,like the sheid one, just trying t figure out what mods and settings i can use on the pump, and what would be a good size injector for that, thanks for the help
92 IC w250 nv4500 conversion, 285/75/16s, Stock pin back in with a little tuning to it, 40hp injectors, * wheel all the way up, he351, 4" turbo back to 6" mitre cut, custom intake, 366 spring, Pump turned up all the way. 226k and still tickin!
The Following User Says Thank You to TheFNG21 For This Useful Post:
haha naw man were good with the single, i made over 600 with the same turbo on my 24v, anyone know what size injectors these motors like, wether it be 6 hole 7 hole or whatever just trying to get some insight
I've got a 64/14 from Industrial Injection, some 150 horse injectors (4x.016), a built pump (by Mountaineer Diesel in WV), and a 4in tbe and it is pretty laggy, especially with me tuning the pump, lol. I can get some of the lag out of it if I crank down the AFC, but then my EGT's are uncontrollable. I've got the AFC one turn down from the top and the pump timed almost clear to the head and it hits about 1400-1450 at the highest. Ireally just need a 62/12 but I'm afraid it won't flow enough air and me EGT's will be even higher, it would be much more practical daily driving though.
1992 W350 reg. cab, built pump built by Mountaineer Diesel, timed to the head, Dynomite Diesel 150 horse injectors, low pressure piston style lift pump, Industrial Injection PhatShaft 64/80/14, 4in. DE tbe, dana80, NV4500, and a Southbend 3250# dual disk.
Part of the problem is those 4 hole injectors and another problem is air in and out.
Before I ditched that 64, I would seriously look into swapping in a cam. A 181/210 Hamilton made a night and day difference in spooling my turbo. It's letting more air into the cylinders along with pushing a lot more out and driving the turbo harder and, as a result, pushing more air back into the motor. It's a viscous cycle
BTW, a 4x.016 is only a little larger than a 5x.014. A 62mm will cool those fine, but again, a 4 hole injector is going to burn hotter anyway. It would be completely different with a 5, 6 or 7 hole nozzle.
You won't make 600 horses with a single on a VE unless you've got a lot of nitrous But injector choice is up to you. Depends on if you want a VCO or a SAC nozzle and how much fuel you need. Do you care if you can't drive it normally without blacking out a 4 lane highway?
There's a sweet 93 ex cab on here lurking around that has twins on it and runs 12.7X 1/4 miles. I saw it put down 489 hp. You can make power with a VE, but it's no where near as easy as running a P-Pump.
