Seventh gauge - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 01-20-2012, 02:02 PM Thread Starter
moparbubba's Avatar
Seventh gauge
Im trying to decided what I should put for my 7th gauge
1. Optix boost
2. Optix pyro
3. Optix trans temp
4. Isspro tach
5. Mopar oil pressure
6. Auto meter fuel pressure
What should I have a real coolant temp a drive pressure or ?
Sent from my DROIDX
Sent from my DROIDX
Ole shakey 92 D250 lots of junk bolted on
New shakey 2010 2500 crew cab long bed smarty jr s&b intake diamond eye exhaust ect ect...
moparbubba is offline
post #2 of 17 (permalink) Old 01-20-2012, 02:07 PM
machineboy93's Avatar
Do a coolant gauge that way you know the true temperature that it is running!
1993 F250 Cummins Conversion, Hx 35 non-wastegated 16 square cm. turbo housing, 40 hp injectors, Denny T Stage II Fuel Pin, Pump turned up a bit, ASA Cold Air Intake, 4 inch MBRP straight axle dump, kdp killed,
machineboy93 is offline
post #3 of 17 (permalink) Old 01-20-2012, 02:08 PM
TheAlmightySam's Avatar
Got airbags? You could run a dual-needle air pressure gauge to monitor them, or a single needle to keep an eye on your OBA if you've got an air tank.
If you do a lot of running of accessories with the engine off, an ammeter is useful to keep an eye on your discharge rate.
That's about all I can think of.
TheAlmightySam is offline
The Following User Says Thank You to TheAlmightySam For This Useful Post:
danb359 (01-22-2012)
post #4 of 17 (permalink) Old 01-20-2012, 04:33 PM
1STGENFARMBOY's Avatar
rear differential temp.
Dar
93 W250, A518, 3.54, DDP 4's, 16cm housing, 60mm Gillett, all pump mods, P/S intercooler, Tim W cooler tubes, carter 4601, 366 spring, denny t pin, homemade BHFF, BHAF, 1/8in bump, 4in DP to 5in , gauges,
1STGENFARMBOY is offline
post #5 of 17 (permalink) Old 01-20-2012, 09:19 PM
90powerram's Avatar
Muffler bearing lubricity indicator gauge.
2002 Ram 2500 24V 6-spd, 4" exhaust & AFE intake
90powerram is offline
The Following 4 Users Say Thank You to 90powerram For This Useful Post:
diesel dawg (07-23-2012), Lucan89 (01-20-2012), moparbubba (01-21-2012), thechoochlyman (01-23-2012)
post #6 of 17 (permalink) Old 01-21-2012, 09:33 AM Thread Starter
moparbubba's Avatar
I removed my muffler bearings and dumpalator valve replaced the 710 and the headlight fluid....
Sent from my DROIDX
post #7 of 17 (permalink) Old 01-22-2012, 01:55 PM
First_Gen_smokuh's Avatar
Blinker fluid level, always good to know how much fluid you have.
Sent from my LG-P925 using AutoGuide.Com Free
1993 W250, 4" TBE, CAI, Intercooler Tubez, Maxed Pump/afc delete, phatshaft 62/65/14, MG Diesels 5x14 Injectors, LPP @ 15psi, Timing to the head, A1 Studs, 3 Piece manifold, 6" lift on 37s, Crossover Steering..more to come!
First_Gen_smokuh is offline
post #8 of 17 (permalink) Old 01-22-2012, 05:42 PM
Clock....?
Drive pressure would be a nice one to have in the cab.
Or a air filter restriction, A.K.A. donaldson gauge
Waiting on EFI live for a 1993,
2" exhaust (think about it.....velocity!)
Rail pressure maxed out
93flatbed is offline
post #9 of 17 (permalink) Old 01-22-2012, 11:54 PM
90powerram's Avatar
I'd put in a coolant temp gauge, that way you can tell exactly where it is.
post #10 of 17 (permalink) Old 07-22-2012, 09:57 PM
Is there a specific kind of ammeter guage to run on a 92 cummins? I just hooked one up to mine and now I'm gettin smoke from under the dash. Very desperate. Replys appreciated greatly
74 F-250 Cummins is offline
post #11 of 17 (permalink) Old 07-23-2012, 07:37 AM
badmfron's Avatar
An "ammeter" measures current in series (in-line) with the circuit so that all electrons flowing through the circuit also have to go through the meter.
http://www.autometer.com/download_instruction/642d.pdf
93-12valve, maxed 12mm ve, 3200 gsk, 5x14 sac injectors, Fass-150 gph, MG 220 amp alt, Steed Speed (vgt) manifold, mechanically controlled he351ve, 5" turbo back, 2-Glowshift 3-in-1, Fluidampr, SBC con-ofe, short throw shifter, homemade adapter plate, ZF6-s750/NP271, 4.88's on 40"s , 12"lift in a super duty
___Banned from B.O.T.T.S.R.
James Oyer
01/05/1978 - 05/28/2012
Wish you were here Jim!!! R.I.P.
badmfron is offline
post #12 of 17 (permalink) Old 07-23-2012, 08:35 AM
Moderator
9297oldram's Avatar
Vacuum gauge from your vacuum pump.
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 SC zf5, 4x4, SAS, 92 Cummins, Bosch 190's, THD fuel pin, THD HVLP with adjustable fuel pressure mod, WM, wh1c hybrid 60/64/.82a/r
9297oldram is online now
