93 12v with no power - Dodge Cummins Diesel Forum
post #1 of 23 (permalink) Old 12-23-2011, 05:59 PM Thread Starter
W00DY's Avatar
Hi I am having a issue with my 12v. I pulled the pump apart to do the fuel pin mod and to tighten down the star and lost one of the copper washers. So i tried another washer and am still having low end torque issues due to low boost. Is all this loss from the washer missing or could I have tightened the star too much or something else I have done wrong. And if it is the washer where could I get a set?
W00DY is offline
post #2 of 23 (permalink) Old 12-23-2011, 06:48 PM
Moderator
9297oldram's Avatar
What kind of a mod did you do on the fuel pin? If you just rotated it and turned the starwheel down that shouldn't have caused any problems. The washer is a cummins item, you'll have to give them your engine S/N and CPL number off the tag on the timing cover.
92 D250 parted out
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 4x4 with 92 Cummins zf5
9297oldram is online now
post #3 of 23 (permalink) Old 12-23-2011, 06:58 PM Thread Starter
W00DY's Avatar
i bought the truck used and it already had a fuel pin in it so i did a full turn on the star wheel. i noticed that it lost power so i opened it back up and i turned the star wheel back to where it was. i have a boost gauge and it used to read around 25 now it barely gets to ten.
W00DY is offline
post #4 of 23 (permalink) Old 12-23-2011, 08:46 PM Thread Starter
W00DY's Avatar
no other washers will work? like the one i had put on there was a metal washer. do you think i could go up to napa and see if they have a copper washer close to that or even would even a nylon washer work?
W00DY is offline
post #5 of 23 (permalink) Old 12-23-2011, 08:56 PM
Moderator
9297oldram's Avatar
A nylon or rubber one from a old car tire tube may get you by.
92 D250 parted out
post #6 of 23 (permalink) Old 12-23-2011, 09:12 PM Thread Starter
W00DY's Avatar
hopefully i will stop by napa in the morning when i get off duty. but do you think that is what my issue is? just that vacuum leak isnt allowing boot to push that diaphragm down in the pump to allow more fuel. also i noticed that i have no take off power is that caused by that also?
W00DY is offline
post #7 of 23 (permalink) Old 12-23-2011, 09:25 PM
Moderator
9297oldram's Avatar
From what I hear you can run without that boost line, there was a thread this week about a broken banjo bolt on that piece you might check that thread. You could put some soapy water on it to see how bad it leaks.
92 D250 parted out
post #8 of 23 (permalink) Old 12-23-2011, 10:01 PM Thread Starter
W00DY's Avatar
thanks for the help. i searched for that thread you were talking about and found a napa parts list that fixes that.
W00DY is offline
post #9 of 23 (permalink) Old 12-24-2011, 10:45 AM
92betsy's Avatar
You can drive without the boost line I've had to. It just keeps the fuel pin from pushing down so less fuel. Kind of like having a valet switch on constantly.
Dustin
92' ext cab d350 dually
92betsy is offline
post #10 of 23 (permalink) Old 12-24-2011, 12:50 PM Thread Starter
W00DY's Avatar
well i went up to napa and they said they didnt have the parts. so i tried finding a different copper washer still no luck. guess it will have to wait till after the holidays. would not having this line on cause no boost?
W00DY is offline
post #11 of 23 (permalink) Old 12-24-2011, 04:58 PM
Moderator
9297oldram's Avatar
As long as the line is capped on the engine your boost should be same as before. You can get those fittings at a hardware store just make sure it has a insert that goes inside the tube.
92 D250 parted out
post #12 of 23 (permalink) Old 12-24-2011, 05:16 PM Thread Starter
W00DY's Avatar
its not. my guage is only reading max of ten PSI it used to go up to right under thirty. do you think i really messed something up by turning that star wheel?
W00DY is offline
