92 VE pump fuel Pressure??? - Dodge Cummins Diesel Forum
View Poll Results: How Much Pressure
3-5 0 0%
5-10 4 22.22%
10-15 14 77.78%
Voters: 18. You may not vote on this poll
post #1 of 29 (permalink) Old 12-06-2011, 09:41 AM Thread Starter
2000cuminspower's Avatar
How much fuel pressure is safe for a VE pump. We put an air dog on my dads 92 and it's running 18 psi. At this site 92 Ram engine specs it shows 18-24 at idle but ive heard that 18 will blow the seals....??? What is the proper supply pressure for a VE? Thanks in advance. BTW its a Brand New injetion pump Thanks!!
2006 3500 6 speed 5.9 Valair Dual disc, 5" with donaldson muffler! Smarty JR.
2000cuminspower is offline
post #2 of 29 (permalink) Old 12-06-2011, 10:22 AM
Moderator
9297oldram's Avatar
The factory service manual says the stock fuel pressure is 3-5 PSI and below 3 psi replace the LP. Yes to much pressure will blow the seals out of the IP. When they run high pressure they locktite the seals in.
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 4x4 with 92 Cummins zf5, Bosch 190's, THD fuel pin, THD HVLP with adjustable fuel pressure mod
9297oldram is offline
post #3 of 29 (permalink) Old 12-06-2011, 12:43 PM
First Generation Moderator
Greenleaf's Avatar
yea.............what he said............
I never really understood that cuz a LIP seal isn't designed to withhold more then 14 psi or is it 16(??) so........lock-tite on the steel body of the seal isn't going to do anything for the LIP..............
Case in point; the John Deere fuel pump. It literally BLOWS the lip out, not the seal's steel body..............
1990 D250/1992 D250 Modified by **Smokehouse Diesel** Ashland, OH
....therefore, my brothers, I want you to know that through Jesus the forgiveness of sins is proclaimed to you. Acts 13:38
Greenleaf is offline
post #4 of 29 (permalink) Old 12-06-2011, 12:48 PM
Moderator
9297oldram's Avatar
I never understood why anyone ever needed to run over 5-7 PSI if you run a gauge you can tell if your pump isn't putting out enough. I run a stock LP and don't have any problems.
post #5 of 29 (permalink) Old 12-06-2011, 01:24 PM
elm302's Avatar
Same happened to me when I put my ad150 on it could hit 20 at times at idle
92 5 speed Isspro Boost pyro tach and fuel pressure timing bump denny T pin 366 spring 4 Inch turbo back to duals three piece manifold Airdog 150 5x16 Valair Clutch Hx35 XD wheels 305/70/16 trail cutters Skyjacker add a leaf
Working on twins
elm302 is offline
post #6 of 29 (permalink) Old 12-06-2011, 01:45 PM
1STGENFARMBOY's Avatar
just with my injectors and turning up the pump i could pull my FP down to 0 as soon as i mashed the pedal, so i had to upgrade.
if you can hold a little preshure theres no need to change it.
93 W250, A518, 3.54, DDP 4's, 16cm housing, 60mm Gillett, all pump mods, P/S intercooler, Tim W cooler tubes, carter 4601, 366 spring, denny t pin, homemade BHFF, BHAF, 1/8in bump, 4in DP to 5in , gauges,
1STGENFARMBOY is offline
post #7 of 29 (permalink) Old 12-06-2011, 02:46 PM
fbabo5's Avatar
yep pretty much the same here. ive also gone through 3 stock lift pumps in the past 3 years so im gunna try an electric one out
1989 W250 Cummins, pump tuned,366 spring,M-5 fuel pin,K&N Air,custom air box,intercooled,HX-40,5x14 injectors,stacks,built 46rh. Dynoed with 727 trans at 332hp and 715ft-lbs at the rw at Diesel Shop dyno days thanks to Beans Diesel Performance with Dyno Dynamics
fbabo5 is offline
post #8 of 29 (permalink) Old 12-06-2011, 03:27 PM
Greenleaf's Avatar
I run the OE piston lift pump because it puts out more flow. With the diaphragm pump (and engine mods) I see O psi of supply, thus, per industry standards,I need to see minimum of 3 psi...............which is actually TOO low in the real world as we have found out with moddified engine operation.
Cummins "thought" that the engine mounted electric supply pump on the ISB engine would get the job done, but, again, in the real world, it don't.
post #9 of 29 (permalink) Old 12-06-2011, 09:27 PM
White Bandit's Avatar
Hows teh piston lift pump working on ur first gen?? i was thinkin bout doin one of them. would u recomend it?? this it the one im looking at. 89-93 dodge 1st gen low pressure piston lift pump
Which piston lift pump do u have?
Thnkx!
-91 250 Regular Cab 5spd,bigger clutch,Built Pump,Denny T,366 spring,Timing,Gauges,4to8in stack,K&N intake,LPLP,Steering Shaft,Gear Box,Ladders Bars,Tires & Wheels.. Follow me on IG @arthuredition
White Bandit is offline
post #10 of 29 (permalink) Old 12-06-2011, 09:42 PM
CaseyF's Avatar
With the mods in my sig, I can bring fuel pressure from 15psi to 10psi when at wot.
01.5 3500 ECLB nv5600 4x4 ISSPRO Pyro, Boost, and Fuel Pressure, AirDog II 165, 5" Exhaust, Valair DD, DAP 7x.013 SAC, 63/68/14, ARP Head Studs, Homemade Spool-Aid, 35/12.50r17 on 3rd gens, Smarty, Ranch Hand Front Bumper. 427hp/867tq before tuner
CaseyF is offline
post #11 of 29 (permalink) Old 12-07-2011, 02:10 AM
Richard LeBar's Avatar
that's exactly right. The misconception is the seal pushes out of its bore. That's not the case. There was actually a guy on DTR who accidentally put a second gen piston lift pump on his mess and filled his case with diesel. Turns out the lip of the seal where it mated to the metal had separated/failed. Too bad I found this info out after machining and locktiting small screws over the edges of the seal...
More related to the OP. I've heard guys running up to 17-18 psi and never heard of a failure.
Like mentioned OE spec is something like 3-5 psi. It should be 10-15. I'd be inclined to say anything at/up to 15 is tried and true so keep it below that, but above the OE recomended low pressure of 3. Even though I'd think that's kinda too low myself...
2003 F250 SD 4x4 3.73 SCSB VE Cummins, 60#, Hamilton pushrods, light home porting, A1 studs, 80lpm injectors, LPLP, home AFC work, stock ground pin, ATS mani (blanketed), s362/68/.7 sxe, 4R100, PCS TCU, gauges, 4" Lift, 35" tires
Richard LeBar is offline
post #12 of 29 (permalink) Old 12-07-2011, 06:06 AM
Greenleaf's Avatar
pump no. 3936320; This is made for the VE injection pump. There are a few items which require change to utalize this pump.
