truck wont shut off - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 07-26-2010, 09:05 AM Thread Starter
truck wont shut off
ok so i got my denny t fuel pin yesterday and installed it all was well ran good shut off fine for awhile thenlater that evening when i turned the key off the engine stayed runnning, so i now have to manually shut the truck down at the pump. i dont think the fuel pin install has anything to do with this. im guessing my fuel shutoff solinoid is bad. but there like 120 bucks at oriellys so i just bought me a pull cable im going to install. my question is will it hurt my injection pump any if the shutoff solinoid doest work? i really dont wana pay 120 bucks when i can just use a cable.
1993 DODGE POWER RAM 250 CTD P PUMPED
2006 DODGE CR GO FAST DAILY TRUCK
FIRST GEN. JAKE is offline
post #2 of 12 (permalink) Old 07-26-2010, 09:07 AM
ROLLIN SMOKE DIESEL
Broke Down's Avatar
iTrader Score: 13 reviews
cable is fine
Duke- 2004.5 2WD SSR Tuned
Feel free to email me for quotes:
Monday-Friday 8am-5pm CST, online ordering 24/7
Broke Down is offline
post #3 of 12 (permalink) Old 07-26-2010, 10:28 AM
unixcowboy's Avatar
VW dealer only wanted $29.95 for the SAME FSS - it's used on the TDI.
Take your old one with you - first parts counter man I spoke to didn't know what I wanted
Tell them it for a VW TDI engine.
2011 Long Bed Crew 3500 w/6 Alcoas set up towing a 40' 5th wheel RV. Custom front bumper/grille guard and rear fender protection
unixcowboy is offline
post #4 of 12 (permalink) Old 07-26-2010, 12:34 PM
MoPowa's Avatar
Welcome to the pull cable club! Actually, installing the fuel pin was the culprit to the shutoff solenoid failing. Same thing happened to me after I installed a DennyT. My understanding is all the extra fueling the DennyT and other pump tweaks combined with stock injectors puts extra pressure on the system and when the fuel goes squeezing by the rubber tip of the solenoid it will tear it off, especially if its a little worn already. Check out http://www.dieseltruckresource.com/d....html?t=117593 if you want to fix the one you have, and stop this from happening in the future. I haven't personally done it, as I like the extra theft deterrent of my hidden pull cable
MoPowa is offline
post #5 of 12 (permalink) Old 07-26-2010, 02:53 PM
unixcowboy's Avatar
Actually ---
it's the other way around ---
Turning up the pump increases the fuel pressure and due to the smaller stock injector holes you get higher pressure. That's what eats up the rubber --- I went through 2 shutoffs before I got my big injectors - haven't had any problems since they've been installed.
post #6 of 12 (permalink) Old 07-26-2010, 03:19 PM Thread Starter
well i see. i just wanted to make sure that the noid being being inoperative wouldnt effect anything else. ima just put a pull cable on it all call it good
post #7 of 12 (permalink) Old 07-26-2010, 03:57 PM
unixcowboy's Avatar
I've got the solenoid working so I don't have to babysit the truck after I drive it for a while. I learned the hard way that the turbo DOES NOT like it's oil supply being stopped when it's hot....
Turbo's are expensive, even the H1C
Now I have a turbo timer on the truck and I can kill the key and lock the truck and the when temps come down the truck shuts off by itself.
BUT I still have a cable - just in case
post #8 of 12 (permalink) Old 07-26-2010, 08:47 PM
1stgenjake's Avatar
ive had a pull cable for about a year now, its nice running around town i can leave the truck running and lock it when i go in the store quick...even better in the winter!
'93 w250- 5x16s, gauges, pump maxed w/pin/spring/spacer/bumped, Amsoil cold air, S362, Valair ceramic, Airdog 150, ARP studs, 24v intake, PS IC, 3" CP's, 3pc m, W/M, traction bars, 4" soft ride front springs, KMC Monsters, 35s.
1stgenjake is offline
post #9 of 12 (permalink) Old 07-26-2010, 09:52 PM
JBradley500's Avatar
x2... i really like that part of it too. i can let my truck cool down (turbo and valve seats) yet use my keys to unlock the garage or house.
the only thing i wish was the AC and Heat would work without the key in while the engine was running. my dog loves the AC so i need to leave the keys in there while i go in the store so he doesnt overheat.
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500 is offline
post #10 of 12 (permalink) Old 07-27-2010, 12:52 PM
blackfordd's Avatar
Here ya go........$10 bucks
$10 Magnetic Valve (Start/Stop Solenoid) for VW Diesel Injector Pumps. VW Diesel TDI
93 W250 LE Club Cab Cummins Turbo Diesel
BD Convertor, HE351cw, POD's, pump maxed, Piston LP, 1/8 bump, 366, DennyT, Isspro Gauges, 4" TB, ASA intake, D70 3.54 LSD, Borgeson shaft
blackfordd is offline
post #11 of 12 (permalink) Old 07-27-2010, 01:24 PM Thread Starter
yea that would be really nice my buddys dads 24v u can take the key out and leave it running and leave the ac or heater on its pretty handy
post #12 of 12 (permalink) Old 07-27-2010, 04:21 PM
unixcowboy's Avatar
My main key does that also so now I use the 2nd key that works the door lock and ignition but not the glove box ( why ??? )....
Only problem with using the main key is that is if someone breaks into the truck the steering is NOT locked and they can just put it in D and drive off
