3rd gen turbo on a 1st gen??? - Dodge Cummins Diesel Forum
post #1 of 22 (permalink) Old 04-04-2010, 12:18 PM Thread Starter
cumminsguy17's Avatar
I have my stock Holset Turbo and wanted to know if i could put it on my first gen 12v motor. Has this been done before? i know that the waste gate on the 3rd gen turbo is electronic so have to figure so way of either blocking it off or putting a mechanical one on it.
2012 3500 G56 bones stock
2004 3500 G56 totaled due to fire
1984 w350 Crew Cab NV500/12v Swap
cumminsguy17 is offline
post #2 of 22 (permalink) Old 04-04-2010, 12:32 PM
Left out in the cold's Avatar
Been done may times. Do a search on HE351.
Left out in the cold is offline
post #3 of 22 (permalink) Old 04-04-2010, 01:43 PM
Smokin ACE's Avatar
yep i got one on mine and love it
92, 14mm VE, 6x18, ED S466, built 47rh
06 3500 cclb g56
Smokin ACE is offline
post #4 of 22 (permalink) Old 04-04-2010, 01:55 PM
913 Cummins 89's Avatar
was your truck a early 2004 or a late 2004 there was a difference in the turbos if itss a late it has the he351 if its early it has a he341. they will both work just fine but the 351 is a little bit better.
p-pumped 1st gen
913 Cummins 89 is offline
post #5 of 22 (permalink) Old 04-05-2010, 03:56 PM
Diesel-less
TexasCummins's Avatar
I thought the HE351's were electronically controlled?
1992 D250
CC/LB | A518 w/ 48RE pan | Tuned VE | Straight piped | Leveled | 33" BFG T/A KO2 on Moto Metal 951
2012 Grand Cherokee Overland 4x4
5.7L Hemi | Diablo tuned | QuadraDrive II | QuadraLift | PoserPods™
1995 Dakota Sport
Forever in a holding pattern waiting on a built big block swap
TexasCummins is offline
post #6 of 22 (permalink) Old 04-05-2010, 04:07 PM
railer and bailer
elephantrider's Avatar
iTrader Score: 10 reviews
hx351 on pre 04.5 motors. he351 on 04.5 +
jason
closet poster
Originally Posted by tco2612 View Post
I would not sell it to you a$$ hole
elephantrider is offline
post #7 of 22 (permalink) Old 04-05-2010, 06:44 PM Thread Starter
My truck was a 2004.5 so its got the bigger turbo if possible could you post some pics of your truck so i can see how u did it. also how did you control the wast gate on yours.
post #8 of 22 (permalink) Old 04-05-2010, 06:56 PM
it is possible most people just lock the waiste gate closed then leaves all the electronics hanging on it to keep the holes pluged up. if you have a non ic truck then you will have o ab a cross over tube if you have a onteercooled truck clock the compressor till they line up and get the boots for the intercooler
p-pumped 1st gen
post #9 of 22 (permalink) Old 04-05-2010, 07:20 PM Thread Starter
Do you have any pics of how you did it on your truck?
post #10 of 22 (permalink) Old 04-05-2010, 10:16 PM
i dont have mine on yet im waiting for boots. but is your truck non i/c? if it is you will need 15 Inches of 2.75 inch pipe or 3 inch pipe whatever you want. go 5 inches from the end and bend it at a 45 degrees. that will replace the cross over pipe/ intake horn whatever you call it. then get a 4x4 inch piece of 1/8th inch thick flat plate. an then 4 inches of the same size tubing you made the cross over pipe with. center the 4 inch peice of tubing on the flat plate then cut out the hole in the flat plate then weld the tubing to the flat plate. that is the peice that will bolt to the intake manafold. the you will need to buy 2 92degree bootes and a 4inch diameter 45 degree boot for and intake
p-pumped 1st gen
post #11 of 22 (permalink) Old 04-05-2010, 10:17 PM
thats the best explanation i can give you
p-pumped 1st gen
post #12 of 22 (permalink) Old 04-06-2010, 02:27 AM
Dieselpolluter's Avatar
There is a way to use the 351cw waste gate. Either you can remove the elctronic valve and plug the hole and drill and tap for a boost elbow or they make a fitting that screws right into electronic valves port. This you can keep use of the waste gate.
92 W250 CREW CAB CR (IN PROCESS)
2005 QCSB
Dieselpolluter is offline
