CumminsForum.com is the premier Dodge Cummins forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 03-11-2010, 10:37 AM   #1 (permalink)
JNDcumminscowboy's Avatar
Question guages
I know there are alot of threads about guages but what I want to know is Glowshif or isspro who is brighter and more reliable I need a boost and pyro bad and how do yall hide the wires??? thanks JOSH
''1991 w250 LE 4x4 5 speed non Ic 3'' off the turbo 6'' tip'' pump turned up! Alot more "COAL ROLLING'' HX35 coming soon and single 7''stack
JNDcumminscowboy is offline   Reply With Quote
Old 03-11-2010, 10:45 AM   #2 (permalink)
1ST GEN MODERATOR
Philip's Avatar
Drill the stock A pillar trim piece and run the wires behind it.
I can't speak for glowshift gages. I have used AutoMeter or Isspro gages. Both work well. Both of those MFG's use standard 194 bulbs. They provide good lighting if the grounds are good on the gages. That also depends on how you wire them also. I wire them into the dash light circuits so the dimmer works on them.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, G56 SBC Con-OFE, 3:07's axles, 2" skyjacker lift, B&W flatbed
Old 03-11-2010, 01:16 PM   #3 (permalink)
Key1989's Avatar
I have Isspro in both my trucks, but my brother recently got some glowshift gauges for his 99 dodge, and I have to say that I like the glow shift gauges "look" a whole lot better, way brighter as compared to the Isspro, and being able to change the color is pretty cool. but I dont like the setup for their boost boost gauge(like the type of hose they use and u gotta use a restrictor in the line, its just pretty retarded IMO.) and Glowshift gauges are setup to where when the gauge is functioning, the lights are on(on the gauges). which kinda sucks during the day b/c the rest of your lights are off then those 2-3 gauges have lights on.
So overall its your decision, but if i had to summarize IMO, I like the looks of glowshift way better but the functioning/set up of the isspro better.
93 W250,Fuel Pin,366,4" in lift,35" tires,Tint 1.9%,dual shocks 93 W350,fuel pin, Airbags(on the front), 3rd gen seats, 5" exhaust from t-case back... 6" Stacks WANTED
Key1989 is offline   Reply With Quote
Old 03-15-2010, 12:46 AM   #4 (permalink)
chromehound's Avatar
just dont use the gloshift two guage A pillar pod. guages have a weird angle in the hole and the top one is hard to read the low end. I run autometer z series...xtra reliable but the pyro dosent lightup as well as the rest
93 W250 Auto;autometer guages;AFE filter;custom air intake;366;tuned pump;POT meter;custom pin;RV-400stall;shift kit,timed
chromehound is offline   Reply With Quote
Old 03-15-2010, 01:29 AM   #5 (permalink)
grizzly_man07's Avatar
the glowshift ones are very bright but you cant turn off the light. it doesnt really bother me though. and what are you talking about with their boost gauges? i was about to order one
SOLD: 91 d250 ic 5sp
92 d250 auto ext. cab. 366 spring. afc MIA straight pipe w/ 5in tip
grizzly_man07 is offline   Reply With Quote
Old 03-15-2010, 12:03 PM   #6 (permalink)
well I got one of those TINY TACKS an some how or other I want to put the 2 gauges with the tny tack on the driver side but I realy dont want a piller pod i was thinking of makeing my own guage mount and putting dimond plate alluminum trim on it or some thing
Old 03-15-2010, 07:20 PM   #7 (permalink)
thats what im gonna do when i get the time
Old 03-15-2010, 08:05 PM   #8 (permalink)
i need to post up pics of my sweet gauge setup that i got an awesome deal on
1993 DODGE POWER RAM 250 CTD ext. cab 4x4 5 speed. fuel screw adjusted, 3200 gov. spring, fuel pin turned, star wheel cranked down, second gen. seat with fold down console, isspro gauges in sweet dash mount, 400 hp valair clutch, more stuff to come
FIRST GEN. JAKE is offline   Reply With Quote
Old 03-15-2010, 08:31 PM   #9 (permalink)
what kinda gauges and what kinda deal?
Old 03-16-2010, 04:26 PM   #10 (permalink)
well i was at a salvage yard for dodges the other day with my buddy cause he wrecked his dually so we was lookin for parts. i was lookin at this old junky first gen and seen these sweet gauges on the dash. there all isspro gauges mounted in a 4 hole pod that mounts on the dash angled towards the driver. i have never seen a pod made like this for a 1st gen. it has a tach, oil temp, egt, and a boost gauge. i knew i had to have it so i ask the man what he would take for the whole thing. he said if i take it off... $ 75 for it all! i said SOLD!! i got it all hooked in my truck now except the oil temp gauge i didnt crawl under the truck to unhook it, i just cut the wires. il try to post up pics soon
Old 03-16-2010, 05:06 PM   #11 (permalink)
dude thats a sweet deal
Old 03-16-2010, 06:15 PM   #12 (permalink)
1ST GEN MODERATOR
Philip's Avatar
That dash pod is a banks setup. It is N/A from Banks. When the rounded trucks came he was like all the other aftermarket MFG's. They forgot that Dodge made a pre 94 truck.
Powered by vBulletin® Version 3.8.5
