- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
![]() ![]() Hoooollyyy what a diference. the old girl gets up and booggys now and what a cloud out that 5in stack. i gained almost 8psi of boost and she is lovin it.![]()
94 Chevy blazer full size with a 12v, 5 speed, 4in exhaust to a 5in stack, 8in of suspention lift and 3in of body"to fit the engine".![]() ![]() denny t fuel pin just installed and tweeked the power pin YEEE HAAA!!!![]()
#2 (permalink) |
you got a non i/c or a I/c 12v in that thing
''1991 w250 LE 4x4 5 speed non Ic 3'' off the turbo 6'' tip'' pump turned up! Alot more "COAL ROLLING'' HX35 coming soon and single 7''stack
#3 (permalink) |
good deal you will be happy that fuel pin
91 W250 5 speed Built trans lots of fuel lots of air south bend clutch denny T stage II 5 inch exhaust traction bars ![]() OHIO COAL ROLLERS |
#4 (permalink) |
here are a couple of ideas that ive been playing with... doing both will probably keep the low boost smoke the same yet give you more top end smoke. ill try to explain the best i can.
if you want more "full boost" smoke....put a 6mm washer between the pin and the diaphragm to get the pin to ride to its deepest position. if you want less "no boost" smoke... take the tophat off and grind where the diaphragm rests on down to about the point where there are 2 grooves already in it (like 3/32")
92 W250(Getrag)- S362/65/12 Turbo, 8x.011" Injectors, Denny T, 366 Spring, Piston Pump, SBC OFE Clutch, 4" Exhaust, M&H Timing Spacer, BHAF. |
#5 (permalink) |
its a non i/c motor and woa does it smoke now and i gained 12 psi of boost. i just might grind down the bottom of the pin off a little to try to get a little more top end smoke.
and i turnes the power screw in about a quarter of a turn also..
#6 (permalink) |
if you want top end smoke dont grind the bottem of the pin grind the top the fuel pin is pushed down when boost comes on not up so grinding the bottom would give bottom end smoke
1989 non I/C w250, WKA stage 3 Fuel pin, He351 turbo, Pump maxed, 3.5 " cat back. Coming soon, 4" exhaust, Custom intake, and 5x14 injectors |
