CumminsForum.com is the premier Dodge Cummins forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 03-11-2010, 12:51 AM   #1 (permalink)
full fuel question
i got my new truck and today i went to turn up the pump. turned the pin 90* the star wheel was only ten clicks from bottom and the smoke screw was already below the nut a bit. the full fuel screw was turned to the collar.
I removed the collar and reinstalled the screw. when i tried to turn it past where it had been set it came tight very quick. I checked the threads and the lock nut was not touching of course.
Has anybody run into this? Could a part be seized or do some pumps not have alot of room to adjust
92 dont know how to fill out my sig lol
mike8061 is offline   Reply With Quote
Old 03-11-2010, 01:43 AM   #2 (permalink)
diesel dawg's Avatar
every pump is different
how are the threads where you removed the collar??
90 w250 4" to 5" dual stacks ,he351cw, pump mods, 727, 1400stall tc, full 1/2 inch fuel system dual filters 100gph electric pump to the ip, full 3" crossover tube
soon to come, w/m setup non ic sticks enlarged to 4x.020 or .022 64/71/14 super b special
diesel dawg is offline   Reply With Quote
Old 03-11-2010, 01:24 PM   #3 (permalink)
#2isgreen's Avatar
I know exactly what you mean, I'm sure you filed out the threads fine, here's what it is: the little o ring is bottoming out and the screw can't go in any further. This happened to me. The only ways to deal with it are A) get the number off your pump and call cummins and get them to send you a new screw, and cross your fingers that its a longer one. I tried this and they sent me a larger diamiter... No use to me..
B) find a guy who can weld, and add 1/8"ish inch to the tip of the screw. Make sure to grind it round a polish it so it doesn't cause harm inside the pump. And don't forget about runaway!!
93 W250 4x4 CC LE. Denny T, Goerends converter, pyro, boost & tach gauges, cooler tubz, 366, fuel cranked, LPLP, 4" straight pipe, timing 3/16th, BHAF, DNR POT kit
06 TDI 5SP. BEST TANK 48.75 MPG RC 1+
#2isgreen is offline   Reply With Quote
The Following User Says Thank You to #2isgreen For This Useful Post:
mike8061 (03-11-2010)
Old 03-12-2010, 01:03 AM   #4 (permalink)
Any one know if a non i/c would have the longer screw? a guy around here has a parts truck but he'd want money just to take it out to compare
Old 03-14-2010, 08:42 PM   #5 (permalink)
My 92 did the same thing and I was wondering if you could just get a longer bolt with the same thread size and use a bolt instead of the stud???
1992 W250 3.55 gears 5spd. pump maxed 1/8 from runaway fuel pin ground fuel pin sping MIA 16CM exh. housing on stock turbo Stock for now clutch stock but ready to EXPLODE H1C Timing maxed to head.
Ledfoot is offline   Reply With Quote
Old 03-14-2010, 11:06 PM   #6 (permalink)
philip_arellano's Avatar
yeah but you would need to make sure it has a place to put a o-ring, so no fuel comes leaking out.
HX35/HT3B, 6X16 INJECTORS, 47RH BULLET PROOF WITH LOCK UP TC. ALL SUPPORTING MODS
philip_arellano is offline   Reply With Quote
Old 03-20-2010, 07:30 PM   #7 (permalink)
There is an oring that can bottom out where is it at on the screw or in the pump???
Old 03-20-2010, 08:53 PM   #8 (permalink)
grizzly_man07's Avatar
on the screw. i would say get a longer screw or weld a 1/8 inch to it
SOLD: 91 d250 ic 5sp
92 d250 auto ext. cab. 366 spring. afc MIA straight pipe w/ 5in tip
grizzly_man07 is offline   Reply With Quote
Old 03-20-2010, 09:22 PM   #9 (permalink)
#2isgreen's Avatar
dont just take it to a buddy who has a stick welder. find somebody who knows how to weld or have an extra screw on hand that you know fits your truck. too high of voltage and your not going anywhere cause the tip will melt off. also, measure it before and after, with a dial indicator so you know exactly what you've gotten yourself into. that measurement will also help you when you put it back in, so you dont go too far in and hit runaway, start near stock settings and work your way in slowly.
Old 03-21-2010, 03:59 AM   #10 (permalink)
welded some amount on lol. put it in and went it half turns till i got it to run away. backed off 1/4 turn. 3200 spring is on its way.
Old 03-22-2010, 10:19 PM   #11 (permalink)
what did you use to weld it???
Old 03-22-2010, 11:42 PM   #12 (permalink)
Has anyone ever taken it and have some silver sodder thrown on the end of the screw instead of welding it? I think that's what I might try if I can't get it to runaway when I turn my fuel screw.
1991.5 W250 3.55 Auto CTD. DDP4, modified DennyT pin , 366, He351, lp plp, 4" ex./straight pipe, ASA intake/EAAU4091 filter ~ 251.4hp/562.5 tq corrected (#1 fuel & bumped timing, no lp plp) ~ Borgeson shaft, Amsoil 5W-30 synth. w/ bypass.
Richard LeBar is offline   Reply With Quote
Powered by vBulletin® Version 3.8.5
