CumminsForum.com is the premier Dodge Cummins forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 03-10-2010, 11:30 AM   #1 (permalink)
delinquent's Avatar
Question Horsepower ???
Does anybody know how many Horsepower can be made without turning the Fuel Screw. Adding injectors, gov springs, custom puel pins, all the afc mods, big turbos etc. I know most people add these things along with turning the fuel screw, but has anybody ever been built to the hilt without touching it?
I'm thinking you could do some pretty good power numbers...what is everybodys opinion.
I know, everybodys gonna say why not turn it...
1991.5 Dodge 250 -6bt. Auto 2wd,SCLB, Bone stock! seriously! I'm not kidding. Still has Factory muffler. Not a thing has been touched!
delinquent is offline   Reply With Quote
Old 03-10-2010, 02:18 PM   #2 (permalink)
Brandonsmokincummins's Avatar
I tuned my pump 30 minutes after i bought my truck
91 W250 5 speed Built trans lots of fuel lots of air south bend clutch denny T stage II 5 inch exhaust traction bars
OHIO COAL ROLLERS
Brandonsmokincummins is offline   Reply With Quote
Old 03-10-2010, 03:03 PM   #3 (permalink)
913 Cummins 89's Avatar
whats the sence of not turning up the fuel screw
1989 non I/C w250, WKA stage 3 Fuel pin, He351 turbo, Pump maxed, 3.5 " cat back. Coming soon, 4" exhaust, Custom intake, and 5x14 injectors
913 Cummins 89 is offline   Reply With Quote
Old 03-10-2010, 03:23 PM   #4 (permalink)
gotacummins's Avatar
injector rating have nothing to do with the pump screw so if you get 80inj you get 80 hp, 140inj 140 hp I havent turned my screw up eithier i waiting for larger injectors, i ve read turning up the screw put more wear and tear on the inj pump I figured 140 inj, fuel pin, and he 351cw would be near maxing out the Head gasket so why turn the screw up?? Of course the main reason for not turning it up is B/C i cant afford a suncoast/goerend TC and tranny hahha
"If JESUS bore the cross and died on it for me, ought I not to be willing to take it up for Him?" 93 D250 club cab AT HE351CW, 4" DP and custom exhaust ,cooler tubz, Denny T pin, 3200k spring, BLK H2's 04F250/12V in Progress:
gotacummins is offline   Reply With Quote
Old 03-10-2010, 03:35 PM   #5 (permalink)
you dont get the hp gain that they say on the box from injectors not how it works. but if you put bigger injectors in you can just get more out of them if your turn the screw in. im not saying you have to but why wouldnt you if it is free and your puting all that stuff on it anyway.
Old 03-10-2010, 03:45 PM   #6 (permalink)
Begle1's Avatar
It helps to understand the operation of the VE pump and how the various adjustments affect it. The throttle position, governor, AFC modifications and fuel screw all act in balance to move the fuel control collar. The farther the fuel control collar moves, the more fuel the pump injects, the higher injection pressure the pumping element creates and the shorter the pump lives.
Things like fuel starvation, fuel overheating and fuel filtration significantly affect pump life too.
AFC modifications will only cause the control collar to move under high-boost conditions, whereas the fuel screw will cause it to be moved farther at all times; this is why it raises idle speed. So it will drop pump life, because you're forcing it to make more pressure.
With larger-than-stock injectors, the maximum pressure that the pumping element will see is going to be lower, and the pump will live longer.
Yes, you can go to large injectors and all of the other pump modifications without ever touching the fuel screw, and doing so will get you maximum pump life. But provided you have a sufficient fuel and air supply, that power screw will always be smiling at you with a free 100+ horsepower.
Sarah McLachlan fact #10:
Sarah McLachlan killed Paul McCartney.
Begle1 is offline   Reply With Quote
The Following User Says Thank You to Begle1 For This Useful Post:
jmd025 (03-10-2010)
Old 03-10-2010, 08:40 PM   #7 (permalink)
delinquent's Avatar
Thats what it is...Pump Life! I have such a good plan now...Project Not enough...Hold on a second!
Powered by vBulletin® Version 3.8.5
