- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
how much power can auto handle
ive got a 93 intercooled auto truck ive only done a intake and turned fuel pin 90 degrees so far.
what would be the limit on the power for the trans(it only has 15000 miles on the tranny) |
#2 (permalink) |
not much
![]() I'd run the power screw in a turn or two and call it good untill you can do something w/ the tranny... as you throw more power at the stock converter, the truck doesn't get much quicker, it just puts a lot more heat in the fluid and nukes the tranny quicker
'06 Mega Cab 2500 4x4 auto. tranny by HotRodDiesels, Smarty, Fleece Performance stand-alone VNT setup, etc. "it makes cool noises" |
#3 (permalink) |
Got P7100?
![]() Join Date: Jul 2008
iTrader Score: 5 reviews
How long have you been waiting to post that pic^^^^??
![]() How much does it cost to build a tranny for the 1st gens in order to hold whatever it is they make hp wise?
2000 QCSB, 175hp p7100, 4gsk, 191dv's, .084 lines and tubes, 7x.014's, maxspool 2.5, 110# springs, head bolts @ 125ft lbs, tranny built by me with DTT parts, AD150, 62/71/14(for now) ohiocoalrollers.com
#4 (permalink) |
start with a good triple lock tourque converter and a shift. convert yours to a lock up you can do that with some switch conversion they make. thats a good start you can make it better thats just a start
1989 non I/C w250, WKA stage 3 Fuel pin, He351 turbo, Pump maxed, 3.5 " cat back. Coming soon, 4" exhaust, Custom intake, and 5x14 injectors |
#5 (permalink) | |
THIS JUST IN: The best way to make your Cummins faster is to replace it with a small block Chevy. ![]() In general, people who consider power mods to be "turning in the smoke screw and turning the AFC cone" aren't likely to break things on a stock transmission unless they melt the thing.
Sarah McLachlan fact #10: Sarah McLachlan killed Paul McCartney. |
#6 (permalink) |
yeah that is pretty much it but you could do input shafts and all that stuff but what i listed is all you would need for a good tranny
#7 (permalink) |
WOW! You can tell who's never been there.
![]() I know this nut who's putting 450/825 to the ground through his A518 that's running increased clutch/steel counts and a better torque converter (non lock-up). Otherwise, it's the stock/OEM hardware. ![]() 1.75 ~ 1.8 second 60's at 6400lbs. Begle's last statement is pretty-much dead-on though. If it were my truck, I'd get a better torque converter the very 1st thing. That'd be the best bang-for-the-buck as far as the trans goes.
David Original owner of a plain'ol '93 W250 ClubCab. Green Folding For Our Future With music by Jewel |
| The Following User Says Thank You to BC847 For This Useful Post: | jmd025 (03-10-2010) |
#8 (permalink) |
if $ isint a big issue ATS diesel makes a good setup with converter and deep pan included
about a $500 diff between 2wd and 4wd setup
93 W250 Auto;autometer guages;AFE filter;custom air intake;366;tuned pump;POT meter;custom pin;RV-400stall;shift kit,timed |
#9 (permalink) | |
91.5 w250 pump maxed, 366, dennyt, he341, airdog 150, orings, 60 lb springs |
#10 (permalink) |
![]() Join Date: May 2008
youd be better off w goerend or sucoast, they have a better rep on this forum by far
"If JESUS bore the cross and died on it for me, ought I not to be willing to take it up for Him?" 93 D250 club cab AT HE351CW, 4" DP and custom exhaust ,cooler tubz, Denny T pin, 3200k spring, BLK H2's 04F250/12V in Progress:
#11 (permalink) | |
![]() I didn't say the wouldn't get quicker, I just said they wouldn't get a lot quicker no need for billet shafts with a non-lockup converter IMO
#12 (permalink) |
TROGDOR!!! THE BURNINATOR!!!
Run that trans till it breaks and fix it up then. Go with Goerends. These are not some wuss honda trannys, they are huge, they have lots of over built parts, and I think it will suprise you what it will hold. Even when it breaks its not like the whole thing will explode. Might break a band, or shear off the input or something, that's when you take it out and build it exactly how you want it.
93 W250 4x4 CC LE. Denny T, Goerends converter, pyro, boost & tach gauges, cooler tubz, 366, fuel cranked, LPLP, 4" straight pipe, timing 3/16th, BHAF, DNR POT kit 06 TDI 5SP. BEST TANK 48.75 MPG RC 1+ |
| The Following User Says Thank You to #2isgreen For This Useful Post: | apascal (03-26-2010) |
