- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
![]() Join Date: Feb 2010
he351 boost psi
i just put my he351 on the runner and i'm only getting around 21 pounds of boost and with my old hx35w i was getting 35 pounds. all i've done so far is pull the elctric part off and plug the hole. is this normal?
1990 toyota 4door 4runner. 1st gen 12v, P.O.Ds, 32GSK. piston LP, HE351. 1/8 turn from runaway. built 47rh with HTS vb and a billet tripple disc t/c. http://www.pirate4x4.com/forum/showthread.php?t=760359 |
#2 (permalink) |
pull that plug and look into the hole. you'll see two holes, one that runs straight in, and a smaller one that runs off at about a 45 degree angle back to the inlet
that little hole has to be plugged, otherwise you are running boost pressure right back to the inlet of the turbo.
'93 W250, 5sp, gauges, pump turned up, DDP Stage IV's, DennyT pin, stacks, BHAF, more on the way as $$ allows, lol OHIO COAL ROLLERS
#3 (permalink) |
I believe that's all the boost you're going to get without an adjustable boost elbow. It will bleed off some of the boost going to the wastegate operator allowing it to build more boost before it opens the wastegate.
#4 (permalink) |
tack wield your waste gate shut
FOR SALE!'93 w250- PODs, Isspro 4k tach, autometer boost, fuel pressure, and EGT gauges, 4" dp to 7" chrome miter cut single stack, BD fuel pin, pump maxed, 366, Amsoil cold air, DTech S300 62/65/12, Valair ceramic clutch. piston lift pump, ARP studs |
#5 (permalink) |
Don't weld anything, but do find a way to keep your wastegate closed. That way, when you decide to sell your HE351, it will be easier.
Then adjust your pump to get boost up to around +/- 38 psi if possible.
1992 Power Ram 250.. dog dish hubcaps and beauty rings. slow, quiet & reliable |
#6 (permalink) |
MOST ARE DRILLING AND TAPING A 1/8 NPT AND installing a boost elbow i cut my solenoid into and make mine i just bought a second he351 to do another conversion and it did not have the solenoid with it. if you go the boost elbow route i would like to buy your solenoid
063500dually4X4qcg56,dynatrac,bd exhaust brake,donaldson m090535muffler,cfm+,winspeed spacer,smartyjr,taylor wings,luberfiner bypass filter,psm cold air,cool hose,tag,air tab's,pdr cam,ddp50hp injectors,htt 62 65 13ss,ss manifold, turbo and manifold blankets |
#7 (permalink) | |
#8 (permalink) |
ɹoʇɐɹsıuıɯpɐ
![]() ![]() Join Date: Oct 2007
iTrader Score: 4 reviews
Do NOT do that. I've had two people PM me already with HE351 issues caused by welding the gate shut. Use a boost elbow.
1999 2500 4x4 CCSB Sport. ADRENALINE/pulse , BHAF, FBD 150 sticks, Tunnel Ram Intake plate, Byrd's intake Horn, HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost & Drive pressure gauges, fuel pressure gauge, FASS 150, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp... 95 Chevy 2500 to get 5.9 24V, NV4500, NP205 and solid axle front. 95 VW Passat TDI VE pump with 1.6 boost pin, shimmed gov spring. 88 Suzuki Samurai with 1.6 VW TD swap, twin cases, and SOA lift, and a lot more 05 Jeep Liberty CRD (wife's diesel) Diablo Power Puck, APS TC, PML pan, Transgo Shift kit, 3" glasspack. |
#9 (permalink) |
On my HE351, the shaft was welded. You should tell us what kind of issues arise when the wastegate is welded shut. I never had any issues with mine, but who would want it now with the shaft welded the way it is? That's why I don't condone doing any welding. A boost elbow is the best way to go no doubt.
#10 (permalink) | |
ɹoʇɐɹsıuıɯpɐ
#11 (permalink) | |
![]() Join Date: May 2008
"If JESUS bore the cross and died on it for me, ought I not to be willing to take it up for Him?" 93 D250 club cab AT HE351CW, 4" DP and custom exhaust ,cooler tubz, Denny T pin, 3200k spring, BLK H2's 04F250/12V in Progress:
