cnc head porting - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 02-25-2010, 09:39 PM Thread Starter
mprmn08's Avatar
cnc head porting
well guys its still being r&d'd but i figured i would get you excited. we got a cummins on the new cnc head porting machine we have the other day. heres some pics of it on there. i'll let you know when we get some flow numbers.
p-69 pictures by mprmn01 - Photobucket
98 2500 4x4 5 speed. exhaust and basic pump tweaks. ported head at the shop waiting to be put on...built motor coming soon.
mprmn08 is offline
post #2 of 15 (permalink) Old 02-25-2010, 09:48 PM
DSTAD's Avatar
Thats aswome. I need one!!!!!!!!!!!!! Btw why dont u just get rid of the intake side and buy one of those bolt on mainfolds. It would flow more and all 6 will get equal cooling
96 3500 2wd, ddp 2s, 3kgsk, #10 plate. Hybrid over s475, bd full roller bearing trans, DiPricol gauges, bd torq loc and tow loc, Pac brake 4 inline, Aux trans cooler with fan, Firestone ride rite with on board air/control, DSS, Centramatics, Maghytec, DDP Boost.
DSTAD is offline
post #3 of 15 (permalink) Old 02-25-2010, 10:40 PM
90powerram's Avatar
Nice - so are you doing a full porting job, or just pocket porting? Just wondering what sort of numbers you'd get from either, but as you said we'll see once you get some numbers off the bench.
2002 Ram 2500 24V 6-spd, 4" exhaust & AFE intake
90powerram is offline
post #4 of 15 (permalink) Old 02-26-2010, 08:40 PM Thread Starter
mprmn08's Avatar
were are gonna do different stages. the minimum will have a full port on the exhaust side and blended on the intake. and we are gonna do a full race port that has the intake cut off and a full head ported and reamed for 14mm head studs if you desire. we are also doing fire ringing, oringing or whatever else you would need done. just to give you some background we did the motor for adam cornells 1300+ hp ford cummins.
mprmn08 is offline
post #5 of 15 (permalink) Old 03-12-2010, 08:34 PM Thread Starter
mprmn08's Avatar
we got 194 cfm on the exhaust today. first flow numbers. gonna do some more tweaking then flow then mess with the intake. let you know when we get more numbers.
mprmn08 is offline
post #6 of 15 (permalink) Old 03-13-2010, 06:27 AM
ZSkibo's Avatar
What kinda cash are we talking about for a stage 1 (?) P&P w/ o-rings, or a stage 2 (?) with the manifold milled w/ o-rings?
92' W250, rhino liner bed+cab. Pump bombed: timing 18*, #366 spring, New Era 6x18's, #60 exh springs, 2ndGen piston pump (@18psi), BHAF, HX40 (60/65/18 T4), 6" hoodstack, full gauges, 4" PAC brake, Airchime P3, SOLD
ZSkibo is offline
post #7 of 15 (permalink) Old 03-13-2010, 07:15 PM Thread Starter
mprmn08's Avatar
not sure. we dont have pricing yet.
mprmn08 is offline
post #8 of 15 (permalink) Old 03-14-2010, 12:27 PM
1stgenjake's Avatar
PM me with pricing for stage 1 P&P with the manifold milled and full race P&P with manifold milled when you figure it out...i wont need fire rings and already have 12mm ARP studs
'93 w250- 5x16s, gauges, pump maxed w/pin/spring/spacer/bumped, Amsoil cold air, S362, Valair ceramic, Airdog 150, ARP studs, 24v intake, PS IC, 3" CP's, 3pc m, W/M, traction bars, 4" soft ride front springs, KMC Monsters, 35s.
1stgenjake is offline
post #9 of 15 (permalink) Old 03-28-2010, 05:49 PM Thread Starter
mprmn08's Avatar
FWIW our 194 exh. flow numbers are with the stock valve in also. PDR's stage 3 port that is 194 cfm flow is with the intake valve put in. friday i cut for the bigger valve but didnt have to flow the head yet. also we realized that the sleeve i had in the flow bench was smaller then the stock bore. so we r making a new sleeve the right size to see what happens. we also got 174 cfm on the intake that we did but my boss did one a while ago that he got 184 or 189 cfm on and we are gonna try and reproduce that one. so i will let you guys know when i get new flow numbers. thanks for watchin.
chris
mprmn08 is offline
post #10 of 15 (permalink) Old 04-06-2010, 10:01 PM Thread Starter
mprmn08's Avatar
got 200.3 cfm today still with the stock valve. I think we might still have a little more room to go but prolly pretty close to max. we tried putting the intake valve in the exhaust side and lost cfm but we're gonna try a couple things and see and if it changes. i'll get you updated.
mprmn08 is offline
post #11 of 15 (permalink) Old 07-25-2010, 07:55 PM
any updates?
"lightly modified" 85 Crew Cab: 92 CTD, 6" lift, South Bend ConO clutch, ISSPRO gauges, 5x.014s, HTT 62/65/13, ported, studded and o-ringed, 4" turbo back, piston lift pump, M2 fuel pin, M&H timing spacer, pump turned up, 3200 RPM governor...
freak007 is offline
post #12 of 15 (permalink) Old 07-25-2010, 08:28 PM
JBradley500's Avatar
how much CSA are you starting and ending with on these ports?
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500 is offline
