First pump mods!
Fellas, Just turned my smoke screw two full turns, rotated the fuel pin about 120* clockwise (I checked after I did this...now riding on deepest part for sure), and rotated star wheel 3/4 of one turn. Everything else is still stock. I have no guages, yet, and want to know if I'm safe, in your opinion, with these settings. How much further can I go? These lights mods really woke her up, and I'm only smoking a bit of haze under full throttle. Full power fuel adj. is tomorrow, and I'll readjust the smoke screw per the instructions after that. What does a 4" TBE exhaust cost? Cheaper to have one made locally at a muffler shop?
1993 W350 Club Cab LE Getrag 2nd owner (parents were first) 130K Miles Banks Stinger Turbo-Tailpipe 3.5" EXH, all else completely OEM and as from Dodge...for a bit! |
#2 (permalink) |
i would not advise going any past that......you need gauges for monotoring egt's and boost pressure. so dont go any farther than you have.
92 W250 club cab 5spd -Eagle Alloys with Discover 35's,4'' rancho lift,K/N filter,4'' silverline exhaust, SW down,2 1/2 turns FPS, SB CON O clutch, autometer boost and pyro,borgeson shaft, cobra 29 LTD NW.custom charger being built. injectors and more soon!
#3 (permalink) |
Did you do mods or did you do adjustments? Sounds like adjustments to me. +1 on gauges, before something bad could happen.
1992 Dodge Power Ram 250: PATC transmission, Suncoast FP, TC and VB, ASA modifieds + AFE filter, Gauges, 366 spring, LP Piston LP, Denny T fuel pin, DDP4's, 3/16" Timing, HE351CW Turbo, 4" exhaust, 7.3 PS Intercooler, and cooler tubez.. |
#4 (permalink) |
thats as far as i would go with out gauges as well full power screw is were things can get hurt when not monitering your egts.
1993 dodge power ram le 4x4 5speed, 6in skyjacker 35in mickey tompson, 16cm turbo housing, afe cold air intake, ddp fuel pin, 4in down pipe 6inch turnout stacks,alot of pump work, bully dog boost and pryo pillar gauges.pods |
#5 (permalink) |
what you did was make your truck run a little better in low boost conditions like around town. you are fine like this. like the other have said you need to get gauges. to get any real gain in power and to make heat you will need to give the fuel screw a few turns. get the gauges first.
92 4x4, fuel screw turned in all the way, starwheel dropped to the bottom, 40 hp injectors, machined pin, detroit locker lets me smoke 'em evenly. auto meter pyro. God Bless Our Country and Damn The Goverment |
#6 (permalink) |
1ST GEN MODERATOR
![]() Join Date: Nov 2007
If those injectors are high milage. I would back that fuel screw out one turn till you get gages.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, auto, 3:07's axles, 2" skyjacker lift, B&W flatbed |
#7 (permalink) | |
#8 (permalink) |
4" turbo back exhaust from Stan's Headers, standard and custom high performance header designs for automotive and marine engines. is like $550 ...made for a 1st gen high quality exhaust. i don't think any exhaust shop can beat that. Boost/EGT pre-turbo mounted pyrometer are a wise choice for now.
1991.0 D250, 5spd, 3.54LS, resto in progress 1993 D250, 5 spd, 3.54, 350k... 3200 spring, +1 turn on power screw, timing +3/16,tranny overfilled 10w-30 |
#9 (permalink) |
1ST GEN MODERATOR
High milage injectors usually have lower pop pressures from age and wear. Turning the fuel screw on a set of those worn injectors without gages could cause engine problems.
