Old 11-06-2009, 12:55 PM   #1 (permalink)
old_school_ctd's Avatar
Holy smokes
I put a Hx35/40 hybrid on this summer and today i finally got a boost gauge installed. Well I about crapped myself when it read 50 pounds of boost, most was 55 pounds. The only mods are listed in my sig. I guess i should put some head studs in next.
1993 W350 built auto, 80hp sticks, head work, pumpwork, 6in stack
old_school_ctd is offline   Reply With Quote
Old 11-06-2009, 12:57 PM   #2 (permalink)
In front of the cloud
johnyb59's Avatar
I'd be careful running it up that high. Things tend to come apart after 40 psi.
2001 SRW QCLB 190 sticks, Xzillaraider/Smarty Revo stack, ARP studs, tst stealth plate, walbro lift pump, leveling kit, autometer has all the gauges covered, Valair ceramic, 4" straight pipe, 64mm 341ve comin "If it weren't for the United States military, there'd be NO United States of America."
johnyb59 is offline   Reply With Quote
Old 11-06-2009, 01:02 PM   #3 (permalink)
Yea i had no idea it would run that high i was figuring the low 30s
Old 11-06-2009, 02:18 PM   #4 (permalink)
The_Head's Avatar
What's the efficiency range for that turbo?
1992 Dodge Power Ram 250, PATC 46RH with Suncoast FP, TC and VB, Denny T fuel pin, 366 spring, New Era 6 x 14's, Low Pressure Piston LP, S362 Turbo on a PDI manifold, custom 4" DP & Exhaust, 7.3 PS I/C, Cooler Tubez, and a few other things. It does ok.
The_Head is offline   Reply With Quote
Old 11-06-2009, 02:37 PM   #5 (permalink)
The compressor map is on this link under technical info
DodgeZilla Turbo City Diesel - Diesel Performance
Old 11-06-2009, 02:46 PM   #6 (permalink)
First Generation Moderator
Greenleaf's Avatar
Don't run it that high. The turbo isn't designed for it.
Do you have an inner cooler? How did you load the engine enough with the factory torque convertor to build that kind of boost? What for exhaust housing is there?
1990 D250/1992 D250 Modified by **Smokehouse Diesel** Ashland, OH
....therefore, my brothers, I want you to know that through Jesus the forgiveness of sins is proclaimed to you. Acts 13:38
Greenleaf is offline   Reply With Quote
Old 11-06-2009, 03:06 PM   #7 (permalink)
I dont have an intercooler, i just held her wot to get it that high, it has a 16cm wastegated housing but it isnt hooked up
Old 11-06-2009, 03:18 PM   #8 (permalink)
peobryant's Avatar
I'd get that wastegate hooked up as soon as possible. Running that much boost on a stock gasket and head isn't smart.
'91.5 D350, 2wd Dually, 4" Straight Pipe, 366 Spring, DennyT Stage II Fuel Pin, Isspro Boost, Pyro, Tranny and Fuel Pressure Gauges
Brothers: '97 2500, 12 Valve, 4wd, 5spd, 716rwhp, 1200+rwtq, Single turbo, Fuel only
peobryant is offline   Reply With Quote
Old 11-06-2009, 03:22 PM   #9 (permalink)
I know, I would have never have guess i made that much boost, just goes to show how important gauges can be.
Old 11-06-2009, 03:23 PM   #10 (permalink)
peobryant's Avatar
What are your EGT's like?
Old 11-06-2009, 03:25 PM   #11 (permalink)
It isnt hooked up yet, i dont have the tap right now
Old 11-06-2009, 03:59 PM   #12 (permalink)
powerbrake's Avatar
old school. you may be very lucky not to have blown parts all to heck. to get that kind of boost takes a lot of fuel and that mean piston melting heat. you better park that thing until you get gauges and consinder yourself damn lucky you still have a truck. i wouldn't be suprised if your egt's were around 1800.
92 4x4, fuel screw turned in all the way, starwheel dropped to the bottom, 40 hp injectors, machined pin, detroit locker lets me smoke 'em evenly. auto meter pyro.
God Bless Our Country and Damn The Goverment
powerbrake is offline   Reply With Quote
