#13 (permalink) |
1ST GEN MODERATOR
![]() Join Date: Nov 2007
![]() You can bet it was well above cummins rated 1250 degrees max EGT's.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, auto, 3:07's axles, 2" skyjacker lift, B&W flatbed |
#14 (permalink) |
Are you sure it's a 16cm with a waste-gate? Didn't know such was available.
Original owner of a '93 W250 ClubCab. Green Folding For Our Future With music by Jewel |
#15 (permalink) |
I meant 12cm, it was off a 97, i got an 18 non wastegated laying around, it would probably do some good to put it on
1990 W250 pump turned up, fuel pin turned to the deepest, advanced timing, 35/40 hybrid 60.5mm comp wheel 4in exhaust, homemade intake, 727 auto |
#16 (permalink) |
i have 2 questions, sorry to get off topic too, but i was wondering don't wastegates lower boost because i had my stock h1c with a 16cm housing and i made 30 -31 psi and i just put on my new s300 with a 12cm waste gate and i only made 25-27, not much of a difference but i had a 250 degree drop in egts. My second question was can you go aboce 1250 for just a couple second then back off or you just shouldn't go over 1250 period.
1992 Dodge CTD, RCLB, W250, 5x.014's, fuel pump maxed, timing 1/8'',bully dog pin, bully dog 4'' exhaust, 366 spring, traction bars, ASA mods intake, and a new 62/65/12 s300 turbo from jacob@diesel auto power, great deal and price, really rollin coal now
#17 (permalink) |
1250 is max so you can run 1200 all day. 1400 and piston will start melting after about a minute and 1600 in about 30 seconds. 1800 will get you 15 seconds or less down the road. these are not written in stone. if you are towing a heavy load and egt's are around 1150 for a couple of hours straight and then you hit a steep hill, if you try to maintain speed and push your egt's to 1450 you will have a quick meltdown as your pistons are already soaked in heat. if you are going down the same road with no load and your egt's are 750 and as you start up the same hill and here comes a guy passing you in a powerchoke, you show him he can't pass your dodge and floor it. now going up this hill you hit 1450 and you hold it there for 30 seconds. most likely no harm will come to your truck because the pistons are not heat soaked and it will take longer for the pistons to heat all the way through. i know i ramble a lot but i hope this helped answer you question.
92 4x4, fuel screw turned in all the way, starwheel dropped to the bottom, 40 hp injectors, machined pin, detroit locker lets me smoke 'em evenly. auto meter pyro. God Bless Our Country and Damn The Goverment Last edited by powerbrake : 11-07-2009 at 11:22 AM. |
#18 (permalink) |
ya that helps alot thanks you very much sir.
