Old 11-04-2009, 10:13 PM   #1 (permalink)
90 model 12 valve power's Avatar
Injector Problems
Well I got my POD's today and went to put them in and 1,2,4,6 came out but the others didnt. This is where it got frustrating. We tried every possible thing there is to do. We broke 4 or 5 wrenches and sockets,pried with crowbars,tried starting it with the POD's in and the 2 stockers but they still wont budge. If this has happened to anybody on here you know how frustrating it is. If anybody has any ideas or anything you have done in the past to get them out let me know.
thanks,dakota
1990 non i/c 12 valve: automatic,pump wicked tweaked, POD's, Custom Intake, Oil Presure Gauge
90 model 12 valve power is offline   Reply With Quote
Old 11-04-2009, 10:19 PM   #2 (permalink)
http://www.dieseltruckresource.com/d....html?t=124728
Check this out, I made one for mine. Works like a charm.
93 Dodge D250- 190 sticks, hx35/super40 hybrid, 4 inch exhaust, Helix 2 cam, 5 speed, pump tweaked, M5 fuel pin. coming soon : powerstroke intercooler, bht3b twins, airdog 150, 3 inch tworline tubes, bigger sticks!! Uncorrected #'s 331 hp 750tq
soot4brains is offline   Reply With Quote
Old 11-04-2009, 11:32 PM   #3 (permalink)
JNDcumminscowboy's Avatar
hey let me know when you get those PODs in if you feel a power upgrade or some thing im ready to order some just need to knowif thy will be worth it thanks JOSH p.s. best of luck pulling injectors
''1991 w250 LE 4x4 5 speed non Ic 3'' off the turbo 6'' tip'' pump turned up! Alot more "COAL ROLLING''
JNDcumminscowboy is offline   Reply With Quote
Old 11-04-2009, 11:36 PM   #4 (permalink)
grizzly_man07's Avatar
well mine were a royal pain in the A$$ too. just make you a slide hammer that screws onto the end of em. i did and it worked great
91 d250, pump maxed. 1/8 in bump timing. BHAF for Freightliner. POD's. HX35 on the way. then puttin this baby on Meth single stack "rollin coal"
grizzly_man07 is offline   Reply With Quote
Old 11-05-2009, 10:46 AM   #5 (permalink)
yeah how did you two like your pods im trying to find some injectors but with mine being non intercooled i dont know what to get thanks
1991 w250 non int, 2 turns on fuel screw,starwheel pegged,6inch lift on 36 inch military tires,gauges,bhaf,soon to be a 5spd
97power ram is online now   Reply With Quote
Old 11-05-2009, 03:42 PM   #6 (permalink)
peobryant's Avatar
If you have a Non I/C truck POD's are a waste of money. Your stock injectors are 4X.012 and POD's are 4X.014. Not enough of a difference to spend $400, in my opinion.
'91.5 D350, 2wd Dually, 4" Straight Pipe, 366 Spring, DennyT Stage II Fuel Pin, Isspro Boost, Pyro, Tranny and Fuel Pressure Gauges
Brothers: '97 2500, 12 Valve, 4wd, 5spd, 716rwhp, 1200+rwtq, Single turbo, Fuel only
peobryant is offline   Reply With Quote
Old 11-05-2009, 03:50 PM   #7 (permalink)
spend the extra and get some 5x12s or 14s
Old 11-05-2009, 04:22 PM   #8 (permalink)
The only reason i got them is because i got them on ebay for $295. And what exactly is a slide hammer?
Old 11-06-2009, 02:49 AM   #9 (permalink)
alright well 6x16 or 18s it is
Old 11-06-2009, 08:50 AM   #10 (permalink)
Post
a slide hammer is where you have a rod or tube with a cap on it. then there is a bigger tube around it about 4in long. on the bottom of it weld a nut that will go on your injectors. screw it your rig on. then grab the 4in pipe and slide it up along the rod as hard as you can so when it hits the cap, it pulls on the injector
Old 11-06-2009, 10:42 AM   #11 (permalink)
how much can i get a set of 6x18's for?
Old 11-06-2009, 11:15 AM   #12 (permalink)
call coaltrain diesel
