Old 11-04-2009, 05:49 PM   #1 (permalink)
CUMMINS7's Avatar
Done Something Custom Lately??
If you could, post some of the neat tricks or ideas or tips that you know. like i seen some guy built his own twin intake manifold, or a way to keep oil circulating better, or maybe new exhaust styles, or how to make your own air intank or ram air, or something you thought of but really dont know how it would work.
92 CTD, I/C, VE Tweaked, ARP Head Studs, 4000 gsk,
CUMMINS7 is offline   Reply With Quote
Old 11-04-2009, 09:02 PM   #2 (permalink)
khaoskustoms's Avatar
Front mount intercooler.
Custom TIG welded 2.5inch piping fabbed with off the shelve 90degree mandrel bends. The hardest part was finding the guts to cut into my brand new front bumper!!! The rest was easy, hold the bends untill you get each end where you need them then weld.
1994 Dodge Dakota Ext Cab 4x4. 4BTA Cummins, 15.09 @ 88mph 1/4 mile, 206hp @ 2700rpm and 446ft/lbs @2200rpm
khaoskustoms is offline   Reply With Quote
Old 11-04-2009, 09:30 PM   #3 (permalink)
CUMMINS7's Avatar
wow thats pretty sweet . whats the pros and cons?? what for intercooler did you use?? what kind of drop in egts?? keep it up!!!!
Old 11-04-2009, 09:31 PM   #4 (permalink)
Begle1's Avatar
I needed a way to purge air out of my 1000 PSI water injection system, as well as a way to ensure that it is working while rolling down the road.
So I installed a pressure washer nozzle in my windshield washer nozzle holder and plumbed it up to another nitrous solenoid.
So now I have 1000 PSI windshield washers. Yeah baby yeah.
110' foot aluminum-framed helium dirigible with 25' living quarters, two 400 HP 12 valves, satellite television and a refrigerator.
Begle1 is offline   Reply With Quote
Old 11-04-2009, 09:45 PM   #5 (permalink)
1ST GEN MODERATOR
Philip's Avatar
Bugs don't stand a chance of sticking now.
Old 11-04-2009, 11:04 PM   #6 (permalink)
1bad93's Avatar
i have an idea if that counts for anything
1993 dodge power ram le 4x4 5speed, 6in skyjacker 35in mickey tompson, 16cm turbo housing, afe cold air intake, ddp fuel pin, 4in down pipe 6inch turnout stacks,alot of pump work, bully dog boost and pryo pillar gauges.pods
1bad93 is offline   Reply With Quote
Old 11-04-2009, 11:06 PM   #7 (permalink)
CUMMINS7's Avatar
yea deff. what is it
Old 11-04-2009, 11:15 PM   #8 (permalink)
Pros, well, its right in the airstream. So I figured in the front was the best place for it. And that was the only place I could find room for it!!! Cons, well, it's right in the front of the truck so it gets peppered by rocks. Next on my list is to put some stainless mesh infront of it. The intercooler I bought used off ebay, it's 3 inches thick, 26x18 inches and has 3 inch in and outlets. EGT's dropped 200 degrees going from non intercooled to intercooled.
Old 11-04-2009, 11:48 PM   #9 (permalink)
1bad93's Avatar
wait is that to me or to the 1000psi bug killers
Old 11-05-2009, 12:25 AM   #10 (permalink)
Key1989's Avatar
I put airbags it on the front of my dually to level it out and help with ride comfort,....its no cadillac ride or anyhting but better, and I like the way it looks
93 W250,Dennyt fuel pin,366,4" in lift,35" tires,Tint 1.9%
93 W350,Dennyt fuel pin, Airbags(on the front), 3rd gen seats, 5" exhaust from t-case back.... 6" Stacks WANTED
Key1989 is offline   Reply With Quote
Old 11-05-2009, 06:53 AM   #11 (permalink)
CrazyktmMatt's Avatar
I polished the beams on my cummins rods when I balanced the bottom end
'90 cummins with way to many mods
CrazyktmMatt is offline   Reply With Quote
Old 11-05-2009, 11:16 AM   #12 (permalink)
The air bags sounds like a great idea.was it a kit? Or did you need to adapt it in? will you tell us how you did it ?Thanks
akula is offline   Reply With Quote
