#25 (permalink) |
1ST GEN MODERATOR
![]() Join Date: Nov 2007
cummins7 that gage pod is N/A now. It was for 1st gen's. I don't know the company name that made it. When those rounded trucks came out in 94. Those pods went N/A like most all aftermarket accessiores for our trucks.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, auto, 3:07's axles, 2" skyjacker lift, B&W flatbed |
#26 (permalink) | |
93 d350 5spd 4inch exhaust to a 6inch tip
#27 (permalink) |
well sorry to keep asking random questions jus dont wanna start a new thread for prolly a stupid question. anyways is $400 a good price for a BHT3B turbo new in the box?? and how much would you want for that guage pod James-93-12valve??
92 CTD, I/C, VE Tweaked, ARP Head Studs, 4000 gsk, |
#28 (permalink) |
That's a banks gauge pod. Can't get them anymore
91.0' W350 SRW LE. 727 3.54s, Dana 80 LSD, 265/75R16E, 366 spring, THIN pin, pump maxed, what starwheel? timing bumped, BHAF, 3.5" straight pipe, rear bagged, Isspro gauges, Hella H4s, Borg shaft.... COMING SOON! big sticks, HX40, 47RH/NV? & DRW swap |
#29 (permalink) | |
#30 (permalink) |
just letting everyone no that i have seen the piller pods single an double on ebay for like $25, or put both together for a triple.that what i did, i got mine for advance auto like 3 years ago
'93 d-350" p-pumped,no plate,2095 rack plug,5x18 custom sticks,laser cut dvs,12mm arp studs,6in miter cut stack,4k gov,60lb valve springs,3in ic,build trans,auto meter gauges,s366/hx60 twin kit in the makin (CUMMINS is the ,Best, forget about the rest!! )
#31 (permalink) | |
89 12v non intercooled, built 727 , power-loked rear pods, 366 spring, dennyt pin, autometer boost, pyro, trans temp, custom intake, 2 stage meth injected, piston pump LP, bhaf, tweaked pump, straight piped |
#32 (permalink) |
Caution, LONG idea
A custom idea I had a while back was for a blow off valve. If you get out of the gas fast, such as shifting a 5 speed, the turbo will surge of bark. If you let out fairly slowly and just coast it takes the turbo a few seconds to spool down and lose all its speed. Boost pressure drops quickly but its still spinning pretty good. If you shift super fast, you may keep a little boost as you grab the next gear, but the pressure in the pipes still wants to exits back through the compressor and slows it down faster. When you get back on it you have to speed it back up. Of coarse a typical blow off valve does not work with diesel engines as they have no throttle plate. But what if we could get a blow off valve to work. This releases all the pressure in the intake tube. Yes, you would lose all your boost, but the turbine speed would stay up and my thought was even though now you must represurize the intake system the turbo speed is still at speed. Maybe? Kinda? I don't know? Ok for the actual "making a BOV valve work" part. Rig it up on the the charge air tube right by the turbo. Instead of using manifold vacuum to open it as on a gasser, use the vacuum our vacuum pump makes that is set up on a air solenoid (such as the ones guys use as a valet switch). When the valve is open, it would allow vacuum to enter the top side of the BOV and open it. To control this valve my idea was 2 criteria must be met. 1. Hobbs switch set at maybe 5 psi?? This would keep the valve closed if were under 5 psi. 2. A micro switch on the throttle so that when you let off the gas, this switch goes to the ON position. If you are above 5 psi but at no throttle, the BOV would open. If you let off from a hard pull it would stay open until it got under 5 psi. If you are at any throttle position other than idle, the valve will not open. The real key is finding a BOV that will not open at 40+psi, or it will overcome the internal spring WITHOUT needing vacuum applied. Find one with a spring that will stand up to whatever boost you push, then when you add the vacumm it will open. I have not tried this yet, but when I get a little extra $$$ I may give it a shot. Could help spoolup between shifts, and also never bark the turbo again. And yes, run a BOV with a muffler so you don't sound like a wanna be ricer ![]() What you all think? Am I nuts![]()
93 Dodge D250- 190 sticks, hx35/super40 hybrid, 4 inch exhaust, Helix 2 cam, 5 speed, pump tweaked, M5 fuel pin. coming soon : powerstroke intercooler, bht3b twins, airdog 150, 3 inch tworline tubes, bigger sticks!! Uncorrected #'s 331 hp 750tq Last edited by soot4brains : 11-06-2009 at 11:38 PM. |
#33 (permalink) |
absolutley, now go build it
92 4x4, fuel screw turned in all the way, starwheel dropped to the bottom, 40 hp injectors, machined pin, detroit locker lets me smoke 'em evenly. auto meter pyro. God Bless Our Country and Damn The Goverment |
#34 (permalink) | |
'93 w250- PODs, Isspro 4k tach, autometer boost, fuel pressure, and EGT gauges, 4" dp to 5" single stack with rain cap, BD fuel pin, pump maxed, 366, Amsoil cold air, He351 55psi, Valair ceramic clutch. piston lift pump, ARP studs .20 over gasket |
#35 (permalink) | |
![]() And a pic of the rear bumper
1994 Dodge Dakota Ext Cab 4x4. 4BTA Cummins, 15.09 @ 88mph 1/4 mile, 206hp @ 2700rpm and 446ft/lbs @2200rpm |
#36 (permalink) |
heres a picture of some apearence stuff i did to the truck got alot more to do though!
93 w-350 5spd intake 4 inch exhaust |
