Old 11-05-2009, 11:51 AM   #13 (permalink)
Key1989's Avatar
Kelderman makes a kit but if i remeber right it was $800, thats to much for me. So I bought a set of airbags for $100 bucks, and built my own brackets out of 5/16" frame rail and the curve of the frame rail I used to my advantage because it matches up perfectly with our frame, I try to post pics.
93 W250,Dennyt fuel pin,366,4" in lift,35" tires,Tint 1.9%
93 W350,Dennyt fuel pin, Airbags(on the front), 3rd gen seats, 5" exhaust from t-case back.... 6" Stacks WANTED
Key1989 is offline   Reply With Quote
Old 11-05-2009, 12:12 PM   #14 (permalink)
CUMMINS7's Avatar
Originally Posted by 1bad93 View Post
wait is that to me or to the 1000psi bug killers
its for 1 bad 93
92 CTD, I/C, VE Tweaked, ARP Head Studs, 4000 gsk,
CUMMINS7 is offline   Reply With Quote
Old 11-05-2009, 12:44 PM   #15 (permalink)
CUMMINS7's Avatar
well got bored today and decided to machine my own fuel pin out of 1/2 stock. I'll let ya know how it compared to my old one jus being ground. (doubt if i can tell the difference but should be better than the one i had) hopefully.
Old 11-05-2009, 12:47 PM   #16 (permalink)
CUMMINS7's Avatar
also does anyone know how far to make the grove?? because at one point if you take to much out the needle wont even reach it correct?? or am i mistaken??
Old 11-05-2009, 12:52 PM   #17 (permalink)
Key1989's Avatar
I am pretty sure if you make the groove to deep the needle as you call it wont go back it and you may be stuck at full throttle( i can be wrong). But i know that the 1/2" stock wont last very long, because Dennyt has to have his pins hardend and it still wears a small groove in it, I dont know what hardening process or what kinda metal he uses but I think he did a lot of research into it, probably more that BD did because I have heard their pins wear down. That just what I have heard.
Old 11-05-2009, 01:30 PM   #18 (permalink)
Key1989's Avatar
Old 11-05-2009, 01:36 PM   #19 (permalink)
Key1989's Avatar
I know its on a second gen, but we did a shortbed conversion on my brothers 99' CTD.
BEFORE
After
Old 11-05-2009, 04:47 PM   #20 (permalink)
CUMMINS7's Avatar
Thats pretty sweet on the air bags and look really good too. and that short bed conversion looks really good also.
and key 1989 your right about the hardness of the material so i switched to a more hardened material (carbide barely cuts it). but i got the main thing done, got the right diameter and length also threaded the end. jus wanna do a little more research in the grove and how much and what angle to take out.
theres a pic of it on my trucks profile dont know how to put it on the forrum
Old 11-05-2009, 05:39 PM   #21 (permalink)
1bad93's Avatar
Originally Posted by CUMMINS7 View Post
its for 1 bad 93
oh well i was board at wal mart (small town with nothing to do) so i found these little cup holder things with cd holders as well so i thought to myself if i took one of these and cut out the part the cds go into and make it so my shifter comes out of their and make a rubber wrap that went into it would look kinda like the commonrail setups and i would have cup holders
1993 dodge power ram le 4x4 5speed, 6in skyjacker 35in mickey tompson, 16cm turbo housing, afe cold air intake, ddp fuel pin, 4in down pipe 6inch turnout stacks,alot of pump work, bully dog boost and pryo pillar gauges.pods
1bad93 is offline   Reply With Quote
Old 11-05-2009, 06:48 PM   #22 (permalink)
CUMMINS7's Avatar
try it and see if it works, nothin worse then a spilt drink in your lap lol
Old 11-05-2009, 08:28 PM   #23 (permalink)
CUMMINS7's Avatar
anybody know if you can buy this guage pod or is it home made??
http://www.cumminsforum.com/gallery/...m/000_0560.jpg
Old 11-05-2009, 10:24 PM   #24 (permalink)
i put parts of 3rd gen cup holders in, a 2nd gen center seat, 2nd gen intercooler, and an S300 from a cat engine. i'm planning on 2x3 rectangle tube steps and front and rear air bag setups. the one that gets the most comments would be the 44mag revolver cylinder shift knob!
92 3/4 ton 4x4 5 speed, ddp fuel pin, ddp4 sticks, fuel screw 1+, lp piston lift pump, 2nd gen IC, cooler tubes, S300, amsoil dry filter,ATS 3 piece manifold, custom exhaust, just another noisy diesel pickup
dnelson is offline   Reply With Quote
