24 valve oil pump
i have heard bits and pieces about the 24 valve oil pumps being a good upgrade for a 12 valve. can anyone tell me if this works and why it is better, if it is? thanks dan
92 3/4 ton 4x4 5 speed, ddp fuel pin, ddp4 sticks, fuel screw 1+, lp piston lift pump, 2nd gen IC, cooler tubes, S300, amsoil dry filter,ATS 3 piece manifold, custom exhaust, just another noisy diesel pickup
#2 (permalink) |
Ok I heard the same thing and I work about 5 minutes from my local cummins dealer and went there with the part number the aftermarket companies shows on the web. Turns out the 24V pump is the newer design. I put one on mine and the pressure is up about 10 psi and the gauge comes up quicker on cold starts. So I think that if you are going anywhere near the pump messing with something else it would be something to look into. BTW the cummins dealer was cheaper than buying on the web.
91' W350 5spd, D60/D80 4.10s, 6" stack, HX35, 2nd gen I/C, pump almost maxed and bumped, stock non I/C injectors, autometer guages. 256hp/565ftlbs Weak. going p-pump.
#3 (permalink) |
ok, thanks for your reply. one day, i don't know when, the cummins will come out for rebuild and i'll be making some upgrades then. just trying to make a list and get some parts rounded up ahead of time.
#4 (permalink) |
so is it worth it and it bolts on the same way or what
''1991 w250 LE 4x4 5 speed non Ic 3'' off the turbo 6'' tip'' pump turned up! Alot more "COAL ROLLING''
#5 (permalink) |
that's what i've heard.
#6 (permalink) |
its a direct replacement part. And def worth it
92 white w250 Le extra cab, 366 spring, flatbed, 4in. from turbo back, toyo mt's, 2 turns star wheel, 3turns on smoke screw,2 turns on fuel screw, custom intake kdp. |
#7 (permalink) |
K thanks do yall know a ruff estamet?
#8 (permalink) |
Yes it bolts right up just like the one that came in it. If memory serves me right I think it was a little less than $80 out the door my cummins dealer.
#9 (permalink) |
that's not bad at all! thanks for all your replies.
#10 (permalink) |
No reason to replace it unless your pump is going south or you're rebuilding your engine.
110' foot aluminum-framed helium dirigible with 25' living quarters, two 400 HP 12 valves, satellite television and a refrigerator. |
#11 (permalink) |
80 bucks aint bad at all I think im going to try to up grade in the next couple of weeks thanks for the info
#12 (permalink) |
good luck getting your oil pan off without pulling the engine.
