Old 11-03-2009, 02:02 PM   #1 (permalink)
Injectors - New Era VS BD VS DDP VS others?
I am looking for some opinions on injectors for a first gen...
I am looking for an injector that when matched to the correct (single) turbo is capable of producing a SUSTAINABLE/TOWABLE 300 RWHP with minimal smoke (smoke on demand is ok ), reasonable heat, and minimal reduction in mileage (increased mileage is better).
If this same injector could be capable of more power (again it must be sustainable power) with twins, awesome... If not, that is okay too.
This is for a conversion. The recipient is a lifted '85 Dodge Crew Cab. Truck weighs 6400 with the stock small block and will gross at weights up to 15,000 (occasionally more). Trans will be a G360, gears are 3.54s and tires are 35"
Now let the opinions fly
freak007 is offline   Reply With Quote
Old 11-03-2009, 02:48 PM   #2 (permalink)
grizzly_man07's Avatar
i got pods. good cheap power. im runnin stock turbo tho
91 d250 ic 5sp with some goodies
"Time to nut up, or shut up" - Tallahassee
grizzly_man07 is offline   Reply With Quote
Old 11-03-2009, 10:02 PM   #3 (permalink)
Richie O's Avatar
For 300 ( usable ) hp your going to need a very good turbo. I have 300 horse at the wheels with my 93 and it is way hot. I can peg the 1500 egt with an empty truck. I have the 60 mm GDS upgraded turbo. You will need a way better set up then that.
89 dodge 3/4 4x4, A727 ,3.07 gears, factory L S , powerstroke intercooler, S300, stans exaust with stainless tailpipe, fuel power screw turned?, fuel pin turned to deepest, 3 turns smoke screw, 1/2 turn down on starwheel. 93 W250 ex cab, 6X16's, 60 GDS, rag
Richie O is offline   Reply With Quote
Old 11-04-2009, 07:43 AM   #4 (permalink)
true true. if you wanna hit 300 i would suggest either the hx40 or a s300
Old 11-04-2009, 09:33 PM   #5 (permalink)
#2isgreen's Avatar
i'm shooting for 300ish too and i was planning ddp 4 injectors (80hp) and a s300. think the ddp 4"s are big enough? also i'm hoping to just re-torque my stock head bolts and keep boost around 35-40 psi.
93 W250 4x4 CC LE. Denny T, Goerends 90% converter, pyro, boost & tach gauges, cooler tubz, 366 spring, fuel screw turned in, stans 4" no muffler, timing 3/16th, BHAF
06 TDI 5SP. BEST TANK SO FAR 48.75 MPG RC 1+
#2isgreen is offline   Reply With Quote
Old 11-08-2009, 10:36 PM   #6 (permalink)
Okay, a lot more research and a few more questions....
What is the general consensus about Coaltrain's injectors?
What would the performance difference between a 5x12 (.0005652 total area) and a 6x11 (total area .0005699) be? - In other words, if the total area is "the same", and spray angle identical, are 5 holes or 6 holes preferred, and why?
Old 11-08-2009, 11:40 PM   #7 (permalink)
1stgenjake's Avatar
i would say 6 hole
'93 w250- PODs, Isspro 4k tach, autometer boost, fuel pressure, and EGT gauges, 4" dp to 7" chrome miter cut single stack, BD fuel pin, pump maxed, 366, Amsoil cold air, DTech S300 62/65/12, Valair ceramic clutch. piston lift pump, ARP studs .20 over gasket
1stgenjake is offline   Reply With Quote
Old 11-09-2009, 03:12 PM   #8 (permalink)
unixcowboy's Avatar
Same area should be the same flow.
BUT --
Would you rather take a shower with 100 psi water pressure using a shower head or a 1" hose ???
Better fuel dispersion = more surface area to burn = better burning of available fuel = more power.
'93 D250 Auto CC HX-40 60/65/17 w/hx50 flange - hit 57 held 55 psi OOPS => 6x16's <=, 366 spring w/1 turn clipped, power screw bottomed-backed off 1 turn, M2 power pin, removed limit washer, smoke screw fully out, starwheel 4 up - modified top to get pin higher, '94 built trans - clutches and some hard parts, 4510 w/4 1/2" intake and heat shield, htr grids MIA, 4" dp -> 5" pipe -> 5" Stack, 285's rear 265's front
unixcowboy is offline   Reply With Quote
Old 11-09-2009, 03:46 PM   #9 (permalink)
Cope Wisconsin Chapter VP
cummins_spool_spinner's Avatar
i like new era IMO but there down right now
92 W-250 CC. Too much to list. (Found on blocks, Reward for Death of Stealers)
Our beer chapter has a diesel problem.
"I'll smack you so fn hard it'll feel like you kissed a train"-Favorite Quote
USMC 2/5 0331. We be steady mobbing
Cope Wisconsin Chapter VP Clicky the Linky---->WISCONSIN COAL ROLLERS
cummins_spool_spinner is offline   Reply With Quote
Old 11-09-2009, 04:44 PM   #10 (permalink)
unixcowboy's Avatar
Try these guys ...
FTE Diesel.com / Diesel Performance Parts for Diesel Pickup Enthusiasts...
Nice, friendly, fast service, GOOD Price -- under $500 delivered with my sticks sent in.
Old 11-10-2009, 07:33 PM   #11 (permalink)
unixcowboy's Avatar
Anyone have an answer as to why the stock stick have the ?????? -- whatever -- in the top where the fuel lines connect ??
The spare set I had and sent in for my 6x.016's didn't have anything but a hole...
That thing in there had to be limiting my max fuel capabilities...
Old 11-11-2009, 01:20 PM   #12 (permalink)
TTipsword's Avatar
Check out Southern diesel extreme. I have a set oredered but they are not in yet. I hear good reports about their sticks. Good price and great coustomer service.
1992 dodge W250, pump maxed, cooler tubz, Denny T pin, SDX 5x.014's
TTipsword is offline   Reply With Quote
