Old 11-02-2009, 10:26 PM   #1 (permalink)
twins
i have a 89 cummins a want to try and build twins i have a stock charger and a 2.5 could i make twins or need a bigger charger to mate up to the stock charger or do i use the 2.5 and get a bigger charger this is a low budget build
haisley dual disc, 4inch exhaust, hidden hitch, smarty box, front leveling kit, rear air bags, spray in bed linner, nerf bars k@n filter
06whiteice is offline   Reply With Quote
The Following User Says Thank You to 06whiteice For This Useful Post:
D_G_R_E_E_N (11-04-2009)
Old 11-02-2009, 10:28 PM   #2 (permalink)
2.5? whats that?
TTipsword is offline   Reply With Quote
Old 11-03-2009, 05:19 PM   #3 (permalink)
1bad93's Avatar
yes im pretty lost on what a 2.5 is and also what kind of injectors your running will also make a diffrence on how the twins will work.
1993 dodge power ram le 4x4 5speed, 6in skyjacker 35in mickey tompson, 16cm turbo housing, afe cold air intake, ddp fuel pin, 4in down pipe 6inch turnout stacks,alot of pump work, bully dog boost and pryo pillar gauges.pods
1bad93 is offline   Reply With Quote
Old 11-04-2009, 06:03 PM   #4 (permalink)
peobryant's Avatar
What are you going to use twins for? Is it going to be a performance truck, or will it be for towing? What is good for towing, isn't the best performance combination.
'91.5 D350, 2wd Dually, 4" Straight Pipe, 366 Spring, DennyT Stage II Fuel Pin, Isspro Boost, Pyro, Tranny and Fuel Pressure Gauges
Brothers: '97 2500, 12 Valve, 4wd, 5spd, 716rwhp, 1200+rwtq, Single turbo, Fuel only
peobryant is offline   Reply With Quote
Old 11-04-2009, 08:49 PM   #5 (permalink)
D_G_R_E_E_N's Avatar
twins
2.5 is what the turbo measures id on housing
1989 dodge 250 4x4 new pump (slightly tweeked) Auto
D_G_R_E_E_N is offline   Reply With Quote
Old 11-04-2009, 08:52 PM   #6 (permalink)
stock turbo has a 3" outlet.
Old 11-04-2009, 08:58 PM   #7 (permalink)
khaoskustoms's Avatar
So a 2.5 would be a 63-64mm turbo?? What's the size of the turbine?? What's the size of the exhaust housing?? What brand of turbo is it?? Holset?? Borg-Warner?? Need more info then just a 2.5 turbo.
1994 Dodge Dakota Ext Cab 4x4. 4BTA Cummins, 15.09 @ 88mph 1/4 mile, 206hp @ 2700rpm and 446ft/lbs @2200rpm
khaoskustoms is offline   Reply With Quote
Old 11-04-2009, 09:46 PM   #8 (permalink)
twins
its off a detroit diesel. Model TV4502
