Old 11-02-2009, 09:23 PM   #1 (permalink)
intermediate steering shaft??
where can i find a replacement or a rebuild kit and how do i get the one thats in it out??
any pictures would be great
Thanks
90w250mm is offline   Reply With Quote
Old 11-02-2009, 10:45 PM   #2 (permalink)
1ST GEN MODERATOR
Philip's Avatar
A complete replacement steering coupler is N/A from Dodge. The rebuild kit you can still get. That runs around $15.
To remove it there is a roll pin in the coupling assy. That roll pin holds the coupling onto the steering box shaft. Remove the roll pin and then drive the coupling off the shaft. Unbolt the two bolts on the rag joint and its off. Now be warned. Support the shaft on the steering box. If you don't it will most likely take the upper seal out.
There is also a replacement steering shaft made aftermarket. Its called a borgenson shaft. It uses an nongreasable u-joint. That assy run around $180.
Old 11-03-2009, 09:05 AM   #3 (permalink)
thanks
Thanks that helps a bunch
Old 11-03-2009, 04:42 PM   #4 (permalink)
Old 'n Rusty's Avatar
I have a Borg' shaft just waiting for one of my rebuilt shafts to get tired. It may never happen and here is why. The first time I replaced a coupler, the original was really loose and when I removed it it oozed a thin 'iron soup'. I replaced it with a used one and in no time it failed as well. More 'iron soup'. The next time I did one I greased the joint with a special marine wheel bearing grease, a heavy blue compound. I slathered it on the outside of the joint as well. I used some plastic ties to hold on a plastic bag which I had wrapped around the joint. I have done this to my two dodges and both are perfectly tight now. If water and dirt can't get in to the joint, it lasts a long time.
It does not even look that bad.
91 (08-90) D250
5sp 2wd 497k VE 'adjusted', 3200 spring, Pyro, boost, 3.54 ,:thumbsup KN, 1\8" timing bump, 25mpg city 30mpg hiway 20mpg towing 6k 5'er
R60/7, Volvo 245 GL, f150 4x4 5 spd, Ram 318, MPG's are in Imp gal's
Old 'n Rusty is offline   Reply With Quote
Old 11-03-2009, 06:26 PM   #5 (permalink)
90powerram's Avatar
You can get the borgeson joint for 180?? Around here guys want ~400 bucks for it! I used a Celica forged steel steering joint on mine, but I have lots of parts around and the means to make it work. No problems yet.
1990 W250 4WD 5-speed, factory 1-ton suspension
Mostly stock for now, pyro, 3.54's & Toyo M/T's
90powerram is offline   Reply With Quote
Old 11-04-2009, 09:34 AM   #6 (permalink)
ok so i got the borg shaft from summit today, how do you get the coupler off is my next question.
Thanks in advance
Old 11-04-2009, 03:11 PM   #7 (permalink)
There should be a bit of orange plastic sticking out of a rolled pin retainer. Remove it and using a fine punch, push out the rolled pin. Lots of penetrating oil can help. Get things real clean so you can see what is going on. I seem to remember that the pin goes in and comes out only one way.... I could be wrong though.
91 (08-90) D250
Old 11-04-2009, 10:00 PM   #8 (permalink)
you can also use a steering shaft off a 94 and newer ram truck. it has u joints like the borgensen and
i believe it's telescopic too.
92 w250 reg cab 5 speed 4x4 rebuilt getrag, valair clutch,18.5cm housing, 60hp bd injectors, 6" skyjacker lift with 37" miltary mtz's
jkelly is offline   Reply With Quote
Old 11-04-2009, 10:30 PM   #9 (permalink)
#2isgreen's Avatar
good luck driving the pin out, mine was flared out on both sides to keep it from slipping and rusted to sh*t. if you un-do the rag joint first you can do the rebuild kit with the whole thing still connected to the steering box. once i got mine apart i realized the tiny pin that needs to be driven into the box to get the guts out was facing towards the block, i had to start the engine and rotate the steering box with vise grips to expose the pin. i used marine grease too, same stuff i pack the bearings on my boat trailer with. water cant hurt what water cant get on.....
93 W250 4x4 CC LE. Denny T, starwheel bottomed out, auto meter pyro & boost gauges, cooler tubz, 366 spring, fuel screw turned in, stans 4" no muffler, timing 1/8th, BHAF
06 TDI 5SP. BEST TANK SO FAR 48.75 MPG RC 1+
#2isgreen is offline   Reply With Quote
Old 11-04-2009, 11:20 PM   #10 (permalink)
well fortunatly for me the pin was not too much of a battle once i found the right size of punch in the tool box, took about 45 minutes to get old out and new in. not near as bad as I thought it would be thanks for all of your help.
Mark
