Old 11-01-2009, 09:52 PM   #1 (permalink)
help with 366 spring wot
i put the spring in. tried to back the full power screw out and it snapped were the o ring is inside the housing but got the top back on and started it up and wot so i shut it off what should i do get a new pump and put the top housing on off of the new one????????? please help thanks
btitus is offline   Reply With Quote
Old 11-01-2009, 10:05 PM   #2 (permalink)
1ST GEN MODERATOR
Philip's Avatar
Did you have the screw backed out when you installed the top????
If you did not have the fuel screw back out. You have broken the AFC lever. At the least you need a new fuel screw and AFC lever.
Old 11-01-2009, 10:18 PM   #3 (permalink)
no it wont back out now what i did was wrapped a wire around that lever and held it forward got the top back on with the screw out then pulled the wire out when i got them tightened im starting to think the runaway is from the throttle levers ive been lookin at some posts
Old 11-02-2009, 10:11 PM   #4 (permalink)
ok i tried every position on the lever i got runaway and no start i cant get it to idle unless i hold my foot on the pedal someone have any idea wat it could be
Old 11-03-2009, 01:43 PM   #5 (permalink)
First Generation Moderator
Greenleaf's Avatar
I would like to help, seriously. I know sometimes I can come across gruff with a "know it all" attitude but, before I can assit you in your quest, you are seriously going to need to use punctuation in what you write as I simply do not understand what you are attempting to convey. I'm sorry.
For an example; In your last post, you stated, I think, that you have tried every position of the throttle lever (in reference to the shaft) and you have run-a-way AND no start?????
I also don't understand the part about snapping off the full power screw and did not mention if you resolved this. I also don't know what your doing with the wire..........
I tried to be as kind as possible here. Punctuation is a must. That is why we have it.
I would like to know more about your situation to offer you some ideas.
1990 D250/1992 D250 Modified by **Smokehouse Diesel** Ashland, OH
....therefore, my brothers, I want you to know that through Jesus the forgiveness of sins is proclaimed to you. Acts 13:38
Greenleaf is offline   Reply With Quote
Old 11-03-2009, 10:33 PM   #6 (permalink)
hey no big deal. I put that spring in and tried to back out the full power screw and it snapped off i cant get it out. So i put a wire to hold the lever forward that the full power screw pushes on. i got the top on and put every thing together . Turned the key wouldnt start so i held the pedal down a little bit and it started up . But as soon as i let go of the pedal it shut off. I figured it was the marks on the shaft and plate. So i turned it a tick mark and i got runaway wot. I have no idea whats going wrong . thanks i hope this is more understandable . if you want you can call me 412 216 5090
Old 11-04-2009, 02:18 AM   #7 (permalink)
dieselcrazyw350's Avatar
there is no reason the full power screw should break.
UNLESS you had tightened it too tight in the first place and when you went to lossen it it broke.
OR (lefty loosey righty tighty) you were backwards and tightened the screw instead of loosening it.
91.5 W350 Getrag G360
92 D250 club cab automatic
http://www.youtube.com/watch?v=oUGlaemOCG4
dieselcrazyw350 is offline   Reply With Quote
Old 11-04-2009, 04:16 PM   #8 (permalink)
no i was loosening it and it snapped off. I did tighten it as far as it would go beforehand though. But i would like to know what i should do i sorta need the truck and i cant get it running.
Old 11-04-2009, 04:56 PM   #9 (permalink)
Greenleaf's Avatar
If the screw is still in there, get it out and buy a new screw. You likely have buggared the threads in the aluminum top.
A wire isn't needed to get this assembly back on the pump. I know some have done that to skip a step or two, but I have read many a post such as your that result in problems and broken parts.
The best method is to read about this assembly, how it works and go slow. By reading ahead you'll know what to expect, how to do it and have minimal (if any) problems.
This task is quite simple IF you don't try to rush it and skip a step like NOT removing all the piece that get in the way. It is a must to make scetches of the parts and take notes about the adjustments beforehand.
What you now need to do is remove the top if not already. Then make sure you didn't break anything. Many break the governor arm.
Old 11-04-2009, 05:01 PM   #10 (permalink)
k thanks. i dont think i will be able to get the screw out though. Is there somewere to get a new top or a screw. Im in PA
Old 11-04-2009, 05:14 PM   #11 (permalink)
Greenleaf's Avatar
Yes. This is what you want. The screw can be had new from any Bosch dealer. You don't want to know the cost of the top. You really need to get a used one from a parts guru. Many guys have old pumps. But you will most likely have to buy an entire junked pump for that top.
You really don't need the same top with the air fuel limiter if you can locate one from another application.
If it were I, I'd get a used one and rebuild it i.e. new throttle shaft and bushing with all new O rings and remove or modify that lever (reverse lever) inside the top. One thing to think about: if you are having troubles with a governor spring swap, you likley will not feel comfortable remanning a pump top. Get it done by a pump guru.
The reason the threads are messed up and the screw broken is because some will turn the screw so tight that the O ring boss will bottom-out inside the cast aluminum and sieze.
Old 11-04-2009, 05:15 PM   #12 (permalink)
now that i look at it the idle spring that the 366 spring hooks onto i put it on as this:
-pin through
-spring
-top hat
-hook 366 spring
were it should go as:
-pin
-spring
-top hat
-slide through
-then hook 366 spring
correct me if im wrong
