Old 11-01-2009, 06:46 PM   #13 (permalink)
Thismachinekillsfascists
jmd025's Avatar
Its not a laggy turbo buddy. And 300-325hp willl spool a 62 mm turbo. Where is this CANT SPOOL it info coming from? Also C-power....no hx35s came on 1st gens.
Louisiana Coalrollers!
VE-P-VP
My trucks are modded.
jmd025 is offline   Reply With Quote
Old 11-01-2009, 06:55 PM   #14 (permalink)
C-Power's Avatar
ok i did some research......mainly talkin to guys with first gens....... they said........ super 40 will work w/ pump turned up.....MIGHT be a bit laggy but not terrible....... but the 6 or 8 blade one would be more laggy.... had a few guys tell me the same thing.....hope this helps....
~2001 GMC DURAMAX Crew Cab~K&N Intake~4in turbo back ~5in miters~Quadzilla Stealth 2 (not impressed)
~3in leveling kit~american racing rims~305's FOR SALE PM ME
C-Power is offline   Reply With Quote
Old 11-01-2009, 10:54 PM   #15 (permalink)
Awesome now we are starting to get somewhere... Maybe I might just learn something...
Now keep in mind that I am a complete noob when it comes to Diesel performance... The 300-350 number is indeed a hope, but I may have set my expectations too high....
Of the 3 goals I listed - driveability is key. I do not want to totally kill my mileage (and would really rather improve it). I want my wife to be able to drive the truck, without me having to worry that she is going to blow something up. The ability to tow is mandatory. I see no sense in having a truck that cannot be used as a truck. Surprising ricers (and 300+ WHP) is a hope... If I can do it without compromising on the other 2 goals, GREAT... If I can't, then I do not want 300+ hp .
Now with that in mind - Let me ask if my goals are realistic for a single turbo? If not, what is a realistic power level for me to shoot for? If it is not realistic, I would be interested in changing the direction of my build, with the intentions of adding twins (and more fuel) further down the road... However it is not in the budget right now....
As for injectors - I do not know. I have been reading alot and I know I do not want POD or marine 370s... I was thinking DDP stage 3 or 4, Bosch 190s, or Pure Diesel Power 120s (5x0.014) or a 5x0.012. I do not know what injectors would be appropriate with my goals (I am not sure if I like the $720 price tag on the DDP Stage 4s either). I do not mind smoke... but not all the time
Originally Posted by crossy's son
Whats the specs on the SUPER s300 for $1100 ?? sounds like good deal.
the price on the H1c and the HX35/40 hyrbrids is crazy though....
You won't break an HX40 shaft with a VE pump, its been discussed before. Lots of overfueled P-pumpers are breaking the HX40's coming down from High rpm and 45psi....
And besides that the SUPER hx40 has an upgraded shaft.
I'd try to go towards a 65mm turbine or bigger...get away from the H1/hx5 60mm turbine...jump up to at least a 65mm
I think the S300 was a 57mm, but I am not sure...
How much USEABLE power can a H1C with the 14cm waste gated housing and 56 to 60 mm compressor support? What injectors would be appropriate for this turbo?
What about a 57mm S300?
PDR HX40?
Super HX40?
What is the HTB2?
freak007 is offline   Reply With Quote
Old 11-02-2009, 03:05 AM   #16 (permalink)
By the sounds of it DDP 4 injectors would suit you well, it's just a matter of whether you want to fork the money for them.
If you can wait until later this week when I try to get my truck on a dyno I can tell you how much power I'm making with my DDP 4 injectors and he351 (rest of my mods are in my sig). My truck has a stock auto so whatever my numbers are, expect yours to be higher. I will say the truck has some berries. She's got some power, that's for sure. My fuel screw is still in the stock position too. I "think" I'm pretty close to 300hp. North of 250 for sure. We'll see though...
For the price I would not get the 57mm s300. For the same price you can get a super 40 and for air flow, that's about the best single you can buy that runs well on a first gen but it'll be about $1000-1100.
A PDR hx40 is a super 40 as far as I know.
1991.5 W250 3.55 Auto CTD. DDP4, modified DennyT pin, 366, He351, 4" turbo back straight pipe, bumped timing. ~ 251.4hp/562.5 tq corrected ~ Borgeson shaft, Amsoil 4091 air filter, home-made intake, Amsoil 5W-30 synth. w/ bypass.
Richard LeBar is offline   Reply With Quote
Old 11-02-2009, 09:51 AM   #17 (permalink)
jmd025's Avatar
57mm compressor is the s300G AKA the BD super B "single", AKA the HTBG, Its a little bit better than a hx35.
Hx40s are a good turbo, if you get the right configuration (there are many out there)....but there's no way I'd pay $1100 dollars for one. You can buy a 62/65/12 or 14 for less than that.
VE-P-VP
Old 11-04-2009, 07:58 AM   #18 (permalink)
What is a 62/65/14? Is that a S300 also?
What are the measurements for the "right" HX40?
Old 11-04-2009, 11:06 AM   #19 (permalink)
jmd025's Avatar
S300 is a "frame size" for turbos...... a 62mm compressor s300 is actually called a s362.
62mm compressor/65mm turbine/14cm^3 exhaust housing.
As far as the hx40s go, it comes down to number of blades on the compressor....and I'm at a loss right now as to which option is the best... Hopefully someone will come along and help out..... I know you could get a 6, 7, or 8 blade compressor, and LOts of exhaust housing choices too.
VE-P-VP
Old 11-04-2009, 11:48 AM   #20 (permalink)
unixcowboy's Avatar
7 blade hx40's are the latest and flow the best.
With an auto a 16 cm spools real good, go to a 14 for a stick.
BE SURE the turbine is a 4" outlet....Get a 4" DP and you're good to go.
WATCH the specs...There's a lot of '40s out there with 3" outlets. That's what you've got stock.
'93 D250 CC HX-40 60/65/17 w/hx50 flange - hit 57 held 55 psi OOPS => 6x16's <=, 366 spring w/1 turn clipped, power screw bottomed-backed off 1/2 turn, Ol Smokey's power pin(modified), removed limit washer, smoke screw fully out, starwheel 4 up - modified top to get pin higher, '94 built trans - clutches and some hard parts, trans cooler in front of radiator, 4510 w/4 1/2" intake and heat shield, htr grids MIA, 4" dp -> 5" pipe -> 5" Stack, 285's rear 265's front
unixcowboy is offline   Reply With Quote
Old 11-04-2009, 11:56 PM   #21 (permalink)
Excellent information guys!!!
Sounds like a Super 40 is the way for me to go...
Now, if I was going junkyard diving, what would I need to look for to find an OEM super 40 with a 16mm housing that would bolt up to my engine relatively easy? What is the going rate for a used one?
Old 11-05-2009, 02:37 AM   #22 (permalink)
as far as I know, the liklihood of finding a real super 40 in a junkyard would be about as likely as winning the lottery. You might find a standard hx40 in a junkyard but as far as I know, you don't want one of those on your truck.
As for going rate for a used one. I don't really know, I'll throw a random guess out there at $500-800?
Old 11-05-2009, 09:05 PM   #23 (permalink)
Well the truck just came off the dyno. With all the mods in my sig (stock setting with the fuel screw) and a completely stock auto tranny I'm putting down 251hp/562 tq. I can REALLY feel a lot of power being sapped by the auto. I wouldn't be surprised if with a manual truck with the same mods someone could put down 290-300, but of course that's just a guess.
Old 11-05-2009, 11:34 PM   #24 (permalink)
ust reading through here again to see if I missed anything...
From what I have been reading the HX40 is only available with a 18 or 16cm housing... is there a 14 available also?? What about wastegates? Since I tow, I was thinking a 14 with a wastegate would be best, but does such an animal even exist?
EDIT - is there any reason I cannot use a "second gen" HX 40 on my truck? What kind of mods would be needed to do this?
