Old 10-31-2009, 03:00 PM   #13 (permalink)
Savemopar's Avatar
well im 19 and have drived my truck everyday since I was 16. I have pulled with it, dragged it, gotten rearended twice and gotten layed in it countless times..Why are yall giving this kid ? And sorry I have out pulled a ford plenty of times I do it all the time where I work. When the 379 gets stuck and so does the loader I gotta pull them out, and the ford that my friend claimed was the couldnt do it lol. But yeah I also take care of the truck but these trucks were made for work anyway not looking like a pretty boy thats what a ford is for....sorrry i had a pointless rant
1993 W-250 HX35, Wastegate clamped, silencer ring removed, ats manifold, green airfilter, straight pipe exhaust, pump tweaked, 6 in lift, glowshift boost and pyro gauges,ISSPRO 3grand tach and ddp3s, 256 rwhp and 606 ft lbs. more to come.
Savemopar is offline   Reply With Quote
The Following 2 Users Say Thank You to Savemopar For This Useful Post:
5.9fan (11-01-2009), 96FordCummins (10-31-2009)
Old 10-31-2009, 05:33 PM   #14 (permalink)
powerbrake's Avatar
if you do pull him you should throw about 800 to 1000lbs of weight in the bed. get it as close to the tailgate as you can. drop your tires down to 20 to 25 lbs. if he does hane 4x4 make sure he doesn't use low range even with the hubs unlocked. if you can get the tires to hokk up the you will out pull him.
92 4x4, fuel screw turned in all the way, starwheel dropped to the bottom, 40 hp injectors, machined pin, detroit locker lets me smoke 'em evenly. auto meter pyro.
God Bless Our Country and Damn The Goverment
powerbrake is offline   Reply With Quote
Old 10-31-2009, 05:40 PM   #15 (permalink)
collin_bucko's Avatar
I really dont think that you would have been able to outpull him in the set up that you have. he has a 4x4 f250 which is much higher at the bumper then your truck. If you would have hooked bumpers, then he basically would have lifted your rear tires off of the ground releasing all traction that you had, and power wouldnt matter in the least bit. The reason I know this is because Ive seen it and it is basic physics. I only do this kind of thing when the two trucks are even in height at the pulling point. This is a true test of power and traction
Forest Green 1999 24V Quad Cab
ATS Built Transmission Looking for a Quadzilla Adrenaline w/ Pulse FASS HPFP 150 Muffler and Silencer Ring mysteriously gone missing...
collin_bucko is offline   Reply With Quote
Old 10-31-2009, 05:50 PM   #16 (permalink)
96FordCummins's Avatar
Haha I dont blame you I use beat the snot out of my ford before i wrecked it. Yeah you guys like to say kids always do childish things, but I have seen my fare share of "adults" do childish things, and more power to them its their truck not yours. So I say congrats to him for stepping up to the bet.
96 Ford F250 4" Suspension 3" Body lift, Just dropped 95 12 valve with #6 Fuel Plate
96FordCummins is offline   Reply With Quote
Old 11-01-2009, 12:29 AM   #17 (permalink)
YOUNG GUNS15's Avatar
i do agree, 2wd reg cab, vs 4wd ford, your going to have some trouble on your hands
94' cummins 12 valve. lots of fuel and a crazy ___ year old
SPECIAL THANKS TO TOXIC DIESEL
YOUNG GUNS15 is offline   Reply With Quote
Old 11-01-2009, 01:55 PM   #18 (permalink)
grizzly_man07's Avatar
well first. we were gonna do it at the gooseneck hitch. second you "adults" cant ever say you havent had one bit of you that wants to show off. oh and we are doin it tomorro so ill tell all you non-beleivers what happens.....
91 d250, pump maxed. 1/8 in bump timing. BHAF for Freightliner. POD's. HX35 on the way. then puttin this baby on Meth single stack "rollin coal"
grizzly_man07 is offline   Reply With Quote
Old 11-01-2009, 02:01 PM   #19 (permalink)
Either way he is still gonna be taller then you and lift your rear tires off the ground. Zero traction = No win.. Good luck man, I hope your able to tow is truck around, but its gonna take one helluva good start on your end to win
Old 11-01-2009, 02:06 PM   #20 (permalink)
his is 2wd. who said it was 4wd?
Old 11-01-2009, 03:41 PM   #21 (permalink)
Richie O's Avatar
Get a movie of it.
89 dodge 3/4 4x4, A727 ,3.07 gears, factory L S , powerstroke intercooler, S300, stans exaust with stainless tailpipe, fuel power screw turned?, fuel pin turned to deepest, 3 turns smoke screw, 1/2 turn down on starwheel. 93 W250 ex cab, 6X16's, 60 GDS, rag
Richie O is online now   Reply With Quote
Old 11-01-2009, 03:55 PM   #22 (permalink)
LostSoul's Avatar
I have to be honest I have had a few people that have talked about their truck. It is natural to try and do it to boost up your truck. I think that we all have done this at one time or another. I love my turd, but I will admit it is not running the way I want it to, but I have been sucked into the I can pull you thing. Had a guy in an Avalanche tell me that he could haul this and that with no problem and that he tow me around. I let his EGO get the better of me, so I grabbed my chain out of the back and hooked him up. He had it in 4x4 and I left it in 4x2 and he was sadly disappointed as all he did was spin tires as I dragged him backwards. Had I used 4x4 I do not think that my truck would have even worked, never mind Lo. You just have to remember that weight wins and make sure you have good U joints or you will break .
1995 2500 4x4 Auto No mods as of yet, too much time modding the fun truck.
LostSoul is offline   Reply With Quote
Old 11-01-2009, 05:09 PM   #23 (permalink)
JNDcumminscowboy's Avatar
Grease them up good and check your diffy fluid dont want it getting hot and blowing maby throwsome tractor waits in the back
''1991 w250 LE 4x4 5 speed non Ic 3'' off the turbo 6'' tip'' pump turned up! Alot more "COAL ROLLING''
JNDcumminscowboy is offline   Reply With Quote
Old 11-01-2009, 07:28 PM   #24 (permalink)
well i doubt it will happen tomorro. tried takin out injectors and can only get three out. so sometime this week we will do it
