#2 (permalink) |
Apparently to the head and beyond. I have mine about an 1/8" advanced but I go back and forth from the head on occasion as well.
92' W250, rhino liner bed+cab. Pump bombed: timing 18*, AFC out, #366 spring, POD's, #60 exh springs, 2ndGen piston pump (@18psi), BHAF, HX35/40 (60/60/12), 4" turbo back 6" stack, full gauges, Banks engine brake, onboard air, train horns! |
#3 (permalink) |
advancing pump
i got the pump lose but it just wont move. got all three nuts just cant get it to go. any ideas. is there somethin im missing? my buddy was helpin me and he has done it on a few trucks and he cant fig it out
91 w250, 12cm housing and the pump tweaked a bit
#4 (permalink) |
I advanced mine to the head and haven't had any issues. As far as moving the pump I had to use a dead blow hammer and a ratchet strap to pull it while I smack it up.
91.5 W250CTD, Automatic, PODS, Pump maxed, Pin shaved, Advanced timing to head, 5" Bullhaulers |
#5 (permalink) | |
There is a Video on Youtube of how to do it.
1995 2500 4x4 Auto No mods as of yet, too much time modding the fun truck. |
#6 (permalink) |
the P-pumps have 4 bolts mounting to the timing case. The VE only has 3.
90 W250 LE, pump turned up, 4" turbo back, I/C conversion, 366 GS, DennyT pin, 6x18's, BHAF, waiting to go in: 14mm h/r, single 5" stack! Diesel is more than a fuel... it's a way of life |
#7 (permalink) |
there ar 3 to the timing case, and one down below the fuel lines.
92 3/4 ton 4x4 5 speed, ddp fuel pin, ddp4 sticks, fuel screw 1+, lp piston lift pump, 2nd gen IC, cooler tubes, S300, amsoil dry filter,ATS 3 piece manifold, custom exhaust, just another noisy diesel pickup
#8 (permalink) |
Some may disagree but I always disconnect all the injector lines when moving them pump. It seems to make sense to me to not be flexing them while moving the pump and eases some of the tension holding it against where you are trying to move it. It does not make sense to hit the pump with a hammer of any type but that's just me. Good luck!
#10 (permalink) |
there are 3 nuts and 1 bolt, that hold the pump like has been said.
'91 350,4x4,5spd,SB3600DD,60/12wg, i/c,366,M&H fuel pin,twin ram intake,gauges,4" exh. http://www.youtube.com/user/91ctddc |
#11 (permalink) |
![]() Join Date: Aug 2008
yeah three nuts and one bolt. I put a strap and ratchet on mine and it tightened it as tight as it I dared go and it didn't budge. Grabbed a rubber mallet and with a few taps I had it right where I wanted it.
89 W250. A727 w/ 3.07s, starwheel bottomed, smoke screw turned out, fuel screw 3/4 turn from runaway, Timed 3/16", DennyT stgII, 366 spring, 12cm exhaust housing, Amsoil air filter, muffler gone, Isspro pyro/boost. G-end TC, 62/71/14 S300, 4" DP to 5" to single 7" miter coming soon when funds allow. 66 Charger, 440 mag, carter 4 barrel, modified cam |
#12 (permalink) |
