choosing injectors
i got my truck togather and running, took it to my old college professor and found 3 the injectors are popping off early. so im gonna upgrade i tow with the truck often but not all the time. normally around 7,000 to 8,000lbs or so nothing to major. i dont want PODs because i hear they really raise egts espessially when towing. i am also going to add a denny T pin, and 366 spring at the same time. i want some decent power but still want a drivable workable truck. thanks o i already have gauges just so ya guys no, also if it helps im running a zf5 and 3.55 gears
96 f350 idi, 4wd, zf5, body lift, 35 inch tires, 5 inch stacks, 12valve conversion underway
#2 (permalink) |
i would suggest a 5x12 or a 5x14, it will add a good amount of fuel flow and still be able to tow 8000 with the egts being reasonable
92 dodge 3/4 4x4, fuel screw 1/2 turn away from runaway, afc wheel smashed, auto meter pyro and boost, 4'' straight piped, denny stage II pin, 5X14 injectors, timing advanced 1/8'', smoke screw all the way down, BHAF. |
#3 (permalink) |
Sounds like 5x.012 would work. Your EGT gauge is mounted PRE turbo right ?
1991.0 D250, 5spd, 3.54LS, resto in progress 1993 D250, 5 spd, 3.54, 350k... 3200 spring, +1 turn on power screw, timing +3/16,tranny overfilled 10w-30 |
#5 (permalink) |
DDP injectors all the way. My next set will be DDP 100's. Here's a link the the 80's Dynomite Diesel - 89-93 Dodge Ram 80 Horsepower Injectors First Gen Dynomite Diesel
1994 Dodge Dakota Ext Cab 4x4. 4BTA Cummins, 15.09 @ 88mph 1/4 mile, 206hp @ 2700rpm and 446ft/lbs @2200rpm |
#6 (permalink) |
Yea DDP4 are awesome injectors. If you can afford them, get 'em
#7 (permalink) |
How are the smoke and mileage with the DDP's? Any difference from 3's to 4's?
92' 250 CTD 4x4- DennyT STG II- Custom intake with K&N filter- turbo and injectors rebuilt-16cm ex housing-Flowpro Muffler-Autometer Boost/Pyro-2 turns on fuel screw |
#8 (permalink) |
The price difference is so little between the 3 and 4 i'd just get the 4. DDP's are a well mannered power making injector, I'll leave it at that. Mileage, same probably. depending how you drive.
#9 (permalink) |
Just so you're aware, even with all of my mods I have no problems with PODs. I'm switching them out for something much larger (5x18's or 5x20's) but for the money they were a great injector despite what everyone else (who probably don't have them) say about them. Good, cheap HP. Yes, there are better injectors out there for a little more cash but if you can find good used PODs you'll be happy.
92' W250, rhino liner bed+cab. Pump bombed: timing 18*, AFC out, #366 spring, POD's, #60 exh springs, 2ndGen piston pump (@18psi), BHAF, HX35/40 (60/60/12), 4" turbo back 6" stack, full gauges, Banks engine brake, onboard air, train horns! |
#10 (permalink) |
Will a stock turbo handle the 4's?
#11 (permalink) |
^^^yeah what he said Im bout to get my set installed next weekend^^^
1993 W-250 HX35, Wastegate clamped, silencer ring removed, ats manifold, green airfilter, straight pipe exhaust, pump tweaked, 6 in lift, glowshift boost and pyro gauges,ISSPRO 3grand tach and ddp3s, 256 rwhp and 606 ft lbs. more to come.
#12 (permalink) |
It really depends on pump tuning. Philip runs big fat 6x.018's and an HX40 in his truck but his pump is 90% stock....and has no problem with EGT's. A mild pump and DDp4's with a hybrid 60mm will do ok. the fuel pin upgrade is what really makes things hot
