Old 10-31-2009, 09:20 PM   #13 (permalink)
i get the same mileage with my ddp's as i did with my stockers. with the pin and fuel screw they are a little smokey till the turbo spools but i still need to advance my timing.
92 3/4 ton 4x4 5 speed, ddp fuel pin, ddp4 sticks, fuel screw 1+, lp piston lift pump, 2nd gen IC, cooler tubes, S300, amsoil dry filter,ATS 3 piece manifold, custom exhaust, just another noisy diesel pickup
dnelson is offline   Reply With Quote
Old 11-02-2009, 01:39 PM   #14 (permalink)
i have a set of ddps stage 4s coming this week, and a gov spring. next week i think im gonna get a fuel pin. im thinking the M2 by M&H anyone use these?
96 f350 idi, 4wd, zf5, body lift, 35 inch tires, 5 inch stacks, 12valve conversion underway
symonds86 is offline   Reply With Quote
Old 11-03-2009, 08:52 PM   #15 (permalink)
dieselfreak01's Avatar
i would get the denny t no personal experience but i have heards tons of good things
'93 d350 drw auto 167000 on the odometer and still running strong, 3.50 gears, ext cab soon to be 5" dp back exhaust
proud member of the OHIO COAL ROLLERS
dieselfreak01 is offline   Reply With Quote
Old 11-03-2009, 10:18 PM   #16 (permalink)
im just curous about towing egts with it, its very hilly here
Old 11-04-2009, 07:25 PM   #17 (permalink)
that mostly just depends on how your pump is set, meaning your power screw. phillip has 6x18 with a mostly stock pump and i dont think he has any problems
Old 11-04-2009, 07:50 PM   #18 (permalink)
i seen on ddp's web site that you can just buy the injector nozzles now has anyone done anything with this im curious cause the 100 horse injectors are only like 400 compared to the 800 for the hole injector
1991 w250 non int, 2 turns on fuel screw,starwheel pegged,6inch lift on 36 inch military tires,gauges,bhaf,soon to be a 5spd
97power ram is offline   Reply With Quote
Old 11-04-2009, 10:38 PM   #19 (permalink)
thanks for the reply i will have to talk to phillip
