Where is the starwheel adjustment? - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 09-15-2009, 06:54 PM Thread Starter
conway_3113's Avatar
Where is the adjustment for the star wheel? Do i have to open up the whole pump or can i get to it from the exterior, pics would be great, thanks in advance guys. Sorry for the question but i couldn't get the info i wanted in the search
1991 single cab, 62/12 phat shaft, 90 hp ddps, bored .60 over, 98 head, 913 pump, Fuel plate mia, 60lbs valve springs, getrag.
conway_3113 is offline
post #2 of 13 (permalink) Old 09-15-2009, 07:42 PM
1stgen3rdgendodge's Avatar
on the top of your injection pump there will be 4 allen head screws. pull all of them out. if its a virgin pump it might take a little convincing to get them broke loose. on the back side of the pump there will be a line with a banjo bolt. cant remember what size it is but you will have to pull that out to. after that you can pull the top of the pump off. you will see a black diaphram, well thats what i call it anyways. you will have to pull that out. it might need a little convincing also to get it out. i know mine did. when you get that pulled out you will see a pin and a spring on the bottom of the diaphram. that is your fuel pin. if you look down inside the pump you will see a cog wheel. get a small flat head screwdriver and turn it cw but just keep count of how many turns you do that way if you want to put it back to stock you can. thats how you adjust the starwheel. when you go to put the fuel pin back in if you look at it you will see that on the cone part one side is steeper than the other. set that pin down in the pump so that the steeper side is facing towards the back of the truck. that will give you an extra little umph also. hope that helps a little bit. i dont have any pictures on hand.
01 2500 QCSB 4x4 - NV4500 Swap, 3600# SD from Kenny's, Quadzilla ADR 4k, 150HP Jammer Nozzles, RSD 4" Down Pipe-5" Straight Pipe, AEM CAI, Raptor 150, Big Line Kit Tank to VP, Leveled, Recon Smoked Cab Lights (110# Springs, HD Rods, Head Studs, in the works)
1stgen3rdgendodge is offline
The Following User Says Thank You to 1stgen3rdgendodge For This Useful Post:
conway_3113 (09-15-2009)
post #3 of 13 (permalink) Old 09-15-2009, 07:59 PM
grizzly_man07's Avatar
Turning up the pre 94 Ram diesel injector pump this should help with all adjustments.. helped me!
SOLD: 91 d250 ic 5sp
92 d250 auto ext. cab. 366 spring. afc MIA straight pipe w/ 5in tip
grizzly_man07 is offline
post #4 of 13 (permalink) Old 09-15-2009, 08:00 PM Thread Starter
much apprectiated, so its not too difficult i take it?
post #5 of 13 (permalink) Old 09-15-2009, 08:03 PM
na its not bad at all. the first time i went to do it i was worried cause of never having done it before. but its actually very easy. im ording a 4k govenor spring the end of this month and it sounds simple to do but since ive never done it before once again im a little worried lol. it is simple though. when you go to put the top back on though do the banjo bolt first other weise you will have a hell of a time trying to get it in cause it wont want to go in straight.
post #6 of 13 (permalink) Old 09-15-2009, 08:04 PM
instead of adjusting starwheel just take out the spring inside the afc. it does the same thing
post #7 of 13 (permalink) Old 09-15-2009, 08:11 PM Thread Starter
so what would be a good start for an adjustment? 1 full turn? maybe 2?
post #8 of 13 (permalink) Old 09-15-2009, 08:16 PM
it will only turn so far. idk how many turns it is. all it does is let the fuel pin go all the way down. if you take out your spring or turn the starwheel i would suggest turning your fuel pin bout 120 degrees or gring it down realllly deep to get max power. i did it and it woke my truck up!
The Following User Says Thank You to grizzly_man07 For This Useful Post:
post #9 of 13 (permalink) Old 09-15-2009, 08:48 PM
well i had pulled my pin out but have decided to put it back in so i just bottomed that wheel out. not sure if im gonna grind my pin or just buy one yet. probably better off buying one
post #10 of 13 (permalink) Old 08-21-2011, 01:18 AM
Would you be gaining or losing mpg by turning the star wheel up from the stock position??
cummings crazy is offline
post #11 of 13 (permalink) Old 08-21-2011, 10:50 AM
92betsy's Avatar
If you want to smoke do this. If you want to tune it for performance and less smoke don't. My starwheel use to sit at the bottom when I first started screwing with it. I got more smoke and my turbo took longer to spool since it just gives it to much fuel to quick. I put the starwheel almost all the way to the top now and way better now. The turbo spools quicker giving my truck better response than before and still blows out way to much smoke but better than sinking the starwheel. It is there to keep your fuel pin to delay fueling depending on how it is set. Using the ramp your fuel pin has matters in my opinion without the spring it fill fuel to hard at first instead of gradually going up the ramp and adding fuel in the process. A little less fuel on take off can help with controlling your turbo spool to a point. This is my opinion that I learned by tinkering with my truck and reading what other people have found to work best.
Dustin
92' ext cab d350 dually
92betsy is offline
post #12 of 13 (permalink) Old 08-21-2011, 03:53 PM
Well I have a 99 dodge 2500 sport and I'm only getting 15 mpg and it don't smoke at all and I want it to smoke. I just don't wanna lose any more mpg
