Old 08-24-2009, 05:31 PM   #1 (permalink)
A-Pump on a first gen
has anybody put a bosh a pump on a first gen? a lot of cummins came with a-pumps, but they were low hp(180) and governed at 2400(i think) the pump im looking at is off a automotive cummins so it has the rqv gov. and has 9.5 mm plungers. how would this be for performance. im sure stock for stock it would out perform a ve pump. but what about modded?
98.5 12v
dsl kicks gas is offline   Reply With Quote
Old 08-24-2009, 05:58 PM   #2 (permalink)
I doubt it will move as much fuel as your VE
'06 Mega Cab 2500 4x4 auto. tranny by HotRodDiesels, Smarty, Fleece Performance stand-alone VNT setup, etc. "it makes cool noises"
drunk on diesel is offline   Reply With Quote
Old 08-24-2009, 09:31 PM   #3 (permalink)
why do you say that?
98.5 12v
Old 08-24-2009, 09:40 PM   #4 (permalink)
1ST GEN MODERATOR
Philip's Avatar
Putting an A pump on???
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, auto(G56 soon), 3:07's axles, 2" skyjacker lift, B&W flatbed
Old 08-28-2009, 01:56 AM   #5 (permalink)
that still dont give me much info.........
98.5 12v
Old 08-29-2009, 11:10 PM   #6 (permalink)
DSTAD's Avatar
Just stick with your stock ve or put a p pump on it. Those are two pumps that are known to work and make lots of power.
91 D-250 Non I/C,Rips 4inch,Airdog 150(Thanks to Matt @ Siskiyou Muffler and Diesel Preformance),Hx35,366 spring,Timing 16.5,Custom ground pin,Custom intake, Di Pricols,US Gear Under Overdrive.
DSTAD is offline   Reply With Quote
Old 09-11-2009, 01:15 AM   #7 (permalink)
I recently put a p-pump on my 91 and couldn't be happier. The P-Pump delivers MUCH more fuel with much more responsive power. To date... The best mod that I have done on my truck!
91smokehouse is offline   Reply With Quote
Old 09-11-2009, 09:47 PM   #8 (permalink)
crossy's son's Avatar
If you know what your doing with a VE pump it'll leave a P-pump in the dust on the bottom end.
My theory is, get what you can get out of the VE then do the swap.
Dont put down 250hp with a VE pump and say "i quit" and put a p-thumper on...theres lots of free EASY stuff you can do to a VE to get good power, P-pump everthing costs money and is harder to get to, you gotta have special tools to adv. the timing on a p-pump
1993 D250, 5 speed getrag, 3.54, 352k... 3200 spring, maxed out power screw, ground fuel pin, timing= alot
1991.0 D250, 5spd, 3.54LS, resto in progress,
crossy's son is offline   Reply With Quote
Old 09-14-2009, 12:26 AM   #9 (permalink)
Yes, I agree. I don't discount the available power of the VE and enjoyed the easy cheap mods! I only decided to convert to the P-Pump after facing the cost of rebuilding mine and finding a great deal on a low mileage p-pump. Although it did cost more than a rebuild on the VE, it was money well spent in my book.
